COOLEME® MB2 Amlogic S912 Octa Core 2G DDR3 RAM 16G eMMC ROM AC 2.4G + 5.8G WIFI 1000M LAN
    Has anyone tested one of these?
    I purchased it at around $39 USD.
    http://www.banggood.com/COOLEME-MB2-...p-1090722.html
    Features:
    COOLEME®MB2, a real Home Entertainment Center for Games/Apps/UHD Videos/Dolby Audio
    Amlogic S912 Octa Core ARM Cortex-A53 CPU up to 2GHz(DVFS)
    ARM Mali-T820MP3 GPU up to 750MHz(DVFS)
    2GB RAM DDR3 + 16GB eMMC Flash ROM
    1000Mbps LAN + IEEE 802.11b/g/n/ac 2.4G+5.8G WiFi + Bluetooth 4.0
    VP9-10 Profile-2 up to 4Kx2K@60fps
    H.265 HEVC [email protected] up to 4Kx2K@60fps
    HDR10 and HLG HDR processing
    Some of the Descriptions:
ID:	627475Click image for larger version
      39$ really ?
        i'm using MB3 google play stopped no firmware update
          Sounds like most every other s912 box. The Ugoos AM3 1.1.0/ 1.1.1 roms should work with it. You may need a modded remote.conf. The Riko MK22 7.1 rom might work as well, especially the one modded for the KM8-Pro.
