Process System isn't responding. Do you want to close it? Micro SD card problem?
    On boot I get the above message, it also occurs in safe mode, if the SD card is removed my T95z boots normally without the warning.
    I have had this problem with the current Superceleron firmware and the various release's of the stock firmware.
    I have tried both 16GB Samsung and currently 32GB Sandisk class 10 micro SD card's, with the same warning message appearing.
    Could it be an Marshmallow card serial identity or write issue?
    The ext SD is identified as Chinese characters NG.
    Hope someone can resolve this
    Thanks Ed
    No, I don't think the problem of "Process System isn't responding" is caused by SD. Instead, it is most likely a device problem. The method of restarting the device, freeing up the phone space, or moving the application from the SD card to the internal storage can effectively solve the process system no responding.
