Need firmware/factory image for bb2 pro / Kb2 pro / Vorke z1 for unbrick
I bricked my Mecool bb2 pro trying to flash with a bb2 (not pro) rom.
Now it doesnt boot and I cannot boot TWRP from SD.
I am looking for firmware or factory image or compatible ROM for BB2 PRO or BK2 PRO or Vorke z1
(as I understood have same hardware),
and some hints on how to try to unbrick it.
Hello friends, this is the last firmware for mecool bb2 pro send to me by videologic https://mega.nz/#F!2JMQnTwC!jbqjn-qqbH81d-59JSm4dA
You can update loading it with the ota app. If you don't boot up, pressing in the reset button (in the back of the device) plug in the power adapter; you enter in android recover menu where you can update the firmware by selecting the menu load from USB or SD....ecc. If you have any problem I'll be more accurate
Thanks to all.
Unfortunately my boot is compromised.. It won't do anything on power on.. Someone suggested me to shortcut pin on the chip.. But I have no enough knowledge to do so.. Thank you anyway!
Superceleron said in pm, if it can help someone:
the only way you have is to put the box in mask mode.. sorry you have Write the boot of it that is why it wont work...
Thanks to all.
Yes I tried.. No way, I want not to read sd..I think the only way is as told by Superceleron.. But I have no info about which pin to shortcut.. Thanks anyway
