SuperCeleron ROM for H96 Pro (not H96 Pro+)
    Was wondering if any of the SuperCeleron ROM's in here can be used with a H96 Pro (not+) 3GB+16GB box. Due to never seeing any updates for these boxes with the q6330 wifi chip in them I have flashed the q9377 firmware on it & so far it works, I don't use wifi or bluetooth on the box so not bothered about those not working. Only issue I am having is my Minix Neo A2 lite air mouse seems to loose the air mouse functionality unless I power off box & power it back on. Seeing so many good reviews in here for SuperCeleron's work I'm hoping that one of his firmware's will work on my box.
    Cheers
    Anyone have any advice?
      There is nothing out there for the H96 Pro! There is an H96 pro + custom firmware,but it will fuk up your H96 Pro if you try to use it. I found out from my own experience.
        Cheers for the post & the warning about H96 Pro+ It's pity that the H96 Pro doesn't have any support or custom firmware available for it.
          Got your H96 Pro bricked, or just wifi/bt has not worked? Im'asking because I have a H96 Pro ( non plus) 3GB DDR3 RAM on q6330 board used via LAN cable.
            Is there any way to fix wifi/bluetooth via recovery?
              Hi all
              Has anyone tried this firmware for the H96 Pro yet? How is it?
              aml_7.1_s912_q9377-H96PRO-KDMC_mac-20170619
