MINIX NEO U9 - H TV Box Octa Core Amlogic S912-H CPU Processor Android 6.0.1 System
    Gearbest
    Brand: MINIX
    Model: NEO U9 - H
    Type: TV Box
    Processor: ARM Cortex A53
    CPU: Amlogic S912-H
    Core: Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 2G
    ROM: 16G
    Max. Extended Capacity: 64G
    Color: Black
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth 4.1
    Power Supply: Charge Adapter
    Interface: 3.5mm Audio,DC Power Port,HDMI,Kensington Lock,LAN,Microphone Jack,OTG,SPDIF,TF card,USB2.0
    Language: Multi-language
    WiFi Chip: AP6335
    KODI Pre-installed: Yes
    KODI Version: 16.3
    Power Type: External Power Adapter Mode
    Power Adapter Output: 5V 3A
    Remote Controller Battery: 2 x AAA ( not included )
    Product weight: 0.2780 kg
    Package weight: 0.9010 kg
    Product size (L x W x H): 12.70 x 12.70 x 2.20 cm / 5 x 5 x 0.87 inches
    Package size (L x W x H): 22.50 x 17.00 x 5.80 cm / 8.86 x 6.69 x 2.28 inches
    Package Contents: 1 x MINIX NEO U9 - H TV Box, 1 x Power Adapter, 1 x OTG Cable, 1 x Micro USB Cable, 1 x HDMI Cable, 1 x Remote Controller, 1 x Antenna, 1 x English User Manual
    any promo code
    MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
      Maybe Soon, MINIX always top dollar for top product
        I have a Neo X8-H Plus & they are well made boxes but way too expensive especially when there are boxes that are much cheaper. My experience with Minix is the box is stuck on the Android version it shipped with back in 2014, firmware updates are mainly to fix bugs that the dev's add in previous updates. This new box is almost £120 - £140 & yet only has 2GB of memory.
          after cnx review....look like nothing special..wifi/rom speed slow than U1....
            Coupon: GBMU9H
            $129.99
            #1
            Gearbest TV Box & Mini PC Page
            #2 Flash Deals Flash Deals
            #3Coupons Coupons, Coupons and More Coupons
              Today we will have a look at the Minix U9-h a lot of the line Android Unit
              Thanks to Gearbest and DHL
              Bit of a look at the PCB
              Now if all boxes could have a heat sink like this, Excellent
              Gearbest
                More on the Minix U9-h, nice and zippy unit for sure, Quality Hardware, DRM L1 for all the goodies
                As always Minix are a little more, Quality Hardware, support and updates is there.
                Excellent Temp control Max seen 60 when pushed with 3Dmark.
                First Boot
                OTA Update
                DRM L1
                Storage & Ram Truth
                CPU-Z
                Vellemo
                Shut Down Feature
                Geekbench4 CPU
                Full Details > https://browser.geekbench.com/v4/cpu/2110404
                Compute
                Full Details > https://browser.geekbench.com/v4/compute/510138
                Antutu 3d
                3DMARK
                A1-SDBench
                System
                  After a Battle with the Boxes, I found my beloved Minix U9-H trying to be a U1 (905) running 5.1 and then the X8-h running 4.4.2
                  But all is well so now we can have a look at SC new and Super ATV a7.1 soon
                  First Impressions Excellent,
                    To Continue.....
                    Not much to say really it works as, ATV should, and coming from superceleron, you would expect no less
                    Its Fast and Zippy
                    L1 HD Netflix smooth as silk, You have the App Drawer, Upper Notification Bar
                    Another Excellent Rom by the Master Blaster
                    Those that have a U9-H i think you will enjoy this fine piece of work.
                    and those that don't have U9-H what ya waiting for
                      Have found Updating Youtube with Playstore can make a mess (know issue)
                      Disable auto update apps and uninstall and re-install if it happens and all will be well.
                      Can detect a Bt remote ok, remote works, just having some trouble getting Voice to work, need to try a few test.
                      Aptoide is there it fill you needs of what Playstore cant
                      Did hours of Music and Netflix all wifi easy smooth as Silk...
                      Should be released I am advised in 24 hours.....
                        The OLE NW-6-404 error, looks like we need a key update form Minix to overcome this problem, Pain
                          Same here. waiting for a solution (using the wonderful freaktab ROM )
