Customize rom?
    Customize rom?
    Hi everybody.
    Recently I started to use this android TV and I like customice some items like bootanimation, launcher........
    Before use Nagrace V6, I used Minix X5 mini, and with the "Rockchip Factory Tool" I changed the bootanimation and some preinstalled APK on it, and keeps unchanged if i had to returm to factory presets, but now, If I try to use Rockchip Factory Tool, don't works.
    Read the img file but al last appears "Read parameter failed" and I can't do nothing.
    Do you know why?
    Do you know another tool to do the changes I told before on Nagrace room?
    Thank you very much
