I have an Amlogic S912 , 2gb ram box and i was looking for a suitable firmware for it , i tried several with many pros & cons .
Today i came across MK22 firmware , i must say , for a rooted firmware it is the best so far.
Wifi works great 2.4 & 5.0 Ghz .
OTA update started automatically.
Kodi auto-updated to v17 , no hiccups .
fast , very reliable firmware.
Wifi chipset : AP6330 universal : " multiple drivers ,ethernet, wifi and bluetooth"
Down side : the system upgrade will delete Launcher 3 for good. otherwise it is clean and light firmware, only Kodi is in the PRE-Install list.
*** You must use MK22 firmware if you have a 2GB Ram device , if you have 3GB , then feel free to try MK22 PLUS.
Download source : www.rikomagic.com
