Date/Time 01/01/2000
    These devices have no battery so what would be a way of making it keep the time when rebooted?
    I know it can update from network but there is not always an internet connection.
    Is there a file where I can change the default date? I could then update this at an interval and at least get a date/time that is only wrong by the amount of time the device has been off.
    Re: Date/Time 01/01/2000
    the default time you can change in the build.prop
    maybe the date also.
    i use always sync with network
    Sent from my GT-S5660 using Tapatalk 2
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      You have no RTC like Snakekiller say the only thing you can do is write Date and Time of a File.
      But the Problem is when you turn of the Device for 4 Days as Example you have a Date that´s not correct.
      May you can Sync your Time with an Atomic Clock Source. But for this you must make some Soldering.
      Neomode
