Q7 RK3188 Media Box Screen gets dark after a while issue ( XT-Q7-V11) 2014-07-14 [SOLVED]
    Click image for larger version  Name:	XT_Q7_V11.jpg Views:	3 Size:	267.5 KB ID:	631372Click image for larger version  Name:	smart multimedia player  4.JPG Views:	3 Size:	19.2 KB ID:	631373 One of my friends handed down this media box since he doesn't use it. It's called Smart Multimedia Player Q7. It came with stock firmware etc and everything works fine except that when i watch a movie or do something and there is a dark scene or a dark screen everything gets very dark as if a mobile phone going to sleep. These are the steps i took and none worked.
    1. Checked it on my Other TV Set
    2. Flashed with different types of firmware and finally revert back to stock
    3. Tried certain apps that keeps the screen awake etc.
    4. Tried a Different HDMI cable
    5. Meddled with all the android settings like sleep, timeout etc.
    These are not my pictures but it's same as mine.
    How do i fix this issue of screen going darker and darker? any idea?
    Looks like i ain't gonna find any answers here.
      Well a little dated yes,
      Sometimes it just takes a little more time.
      Maybe another power supply
        You will have to be patient.
        There may not be many users of this device as it's quite old now.
        In the mean time it's worth scanning the threads here to see if anybody else has posted a similar problem in the past.
        http://freaktab.com/forum/tv-player-support/rk3188-devices
          Thanks for the idea. Let me try that.
            Alright.... i just tried switching the power supply. That doesn't work either but thanks a lot for all the help. Any recommendations on upgrading firmware?
              Such boxes came in many flavours with different hardware inside, including a lot of clones, so in order to ascertain the right firmware I would recommend that you open the box and take some detailed pictures of all the components.
                The picture i posted is exactly the same even though its not mine because i opened mine and took a very close comparison. If it is really necessary i will do that tomorrow. Thanks a lot for all the help.
                  By the way i went through those box identification guides. it is exactly the same. Q7 with RK3188 with the same date and motherboard number.
                    Have a look at this thread
                    http://freaktab.com/forum/tv-player-support/rk3188-devices/k-r42-cs918-mk888-jesurun/17589-new-ekb311b-from-eny-technology-xt-q7-v11-2014-07-14
                    Post 33 indicates a link to a firmware update from 2015 on Yandex for the board reference xt-q7-v11
                      thank you for helping me out in this. Yes i went there and right now i am downloading it. Let me upgrade and i will post the results. thanks a lot and many blessings to you.
                        Sir! i just did used the firmware you suggested. It works perfectly, the only problem is that getting dark thing still there as it was before. So i am going to take my TV Box to the mother in law's place and use it on her TV too. I have two LG's and she has a much newer LG. Let's see if it works.
                          Alright.... finally i have found the culprit behind screen getting dark. I am writing in so anyone who may have encountered this problem will know that it is not a problem with TV box, it's the TV.
                          I have two LG Tv's, one is bought around 2013 ~ 2014 (32inch smart LED) the other one is around 2015 42 Inch (LED/non smart)
                          I checked it on a 2016 END ~ 2017 LG 32inch (non smart LED) TV and the problem is not there.
                          Both of those above sets have the problem with above tv box that dark scenes get darker and darker. My other TVBOX which is nexbox A95X (S905) doesn't have this problem. No matter how i tried, so far i have failed to sort this problem out. If i figure out a cure for this i will post it in time to come.
                            Hi everybody. I found a solution and finally it worked. There are few ways to doing it. Some are hard and requires knowledge in electronics and there are easy methods too. First i'd like to share the forum page which led me to the solution.
                            Does anybody know how to turn off LG's Global Dimming? I have the 60LB7100 and this global dimming sucks. I calibrated the TV and I know all about the settings. Energy savings is off and I even tried turning off local dimming. It is really bad in the opening on Star Trek TNG. Dark space gets...
                            There is a video about doing it in the more electronic hard way. here it is and i didn't try it.
                            youtube.com/watch?v=RZIgn7GlTGQ ( this is in the post #20)
                            Method that worked for me was much more simple.
                            Post #12
                            Simply changing the input method to PC worked right on spot for my 42' TV. PHEW!!!
                            So i would like to thank everyone who tried to help me in this.
                              Glad you got it resolved and thanks for posting the solution to the darkness issue which I am sure will be useful to many.
