Pippo M6 max
RileyROM 1.6
Hi, I have a pipo m7t & had a similar problem when trying to get a rom where kitkat didn't have random crashes/restarts.
Presuming from your post that you have read the pipo forums and have downloaded & installed the the rockchip batch files & 1.6 RileyRom.
Start the rockchip tool.
To get into flash mode on a m7t:
Ensure tablet is powered off. (If you press the power button, you may notice the screen flickers a bit as if waking up from screen save - nothing displays on screen)
So hold/press power button down for about 20 seconds to ensure tablet is powered off.
Press & hold the 'Esc' button then press & hold the 'Power' button. The rockchip tool will then recognize the tablet ( This worked for my m7t)
Hope this works for you if you haven't already fixed it.
Hi Senistation ,
look here at Post #109 , the Pipo Tablets are nearly unbrickable with wrong flashing.You have to press about 45 seconds to a minute to be sure.
http://freaktab.com/forum/tablet-sup...feedback/page8
otherwise look for shorten the Nand if this does not help.
good Luck
Greetings
gefattern
There are currently 1498 users online. 0 members and 1498 guests.
