GV 4k box 16g 2g firmware 5.1.1 s905 not allowing install of many aps
    Is there better firmware I can usb load for this box
    hx 905 series version 5.1.1 build june 6th 2016
    Its the s905 not s905x
    I purchased this box due to 16 gig and 2gig but most aps on play store says incompatible device type,
    Even when I try installing an apk file I get similar problems.
    Is there a firmware 16/2 anyone would recommend from china gadgets that may would solve these problems different manufacturer is a possibility.
    I also have a s905x and this works great and I updated it to marshmallow without a problem from a different manufacturer.
    Thanks, if anyone can advise.
    orion r28 android ver 4.4.1, new Kodi Krypton won't load without 5.1 downloaded mediafire file with a .7z ext. cant find anything to open
      Does anyone know of a 5.1.1 firmware that I can download?
      My friend have 5.1.1 on 8/1 memory boxes and everything works great.
      Can I put the 8/1 firmware on and loose some memory?
