Is there an update to Android 5 or 6, or is that not possible?
Also, what does Finless mean? Or is it just a name?
Figured I would get the best advice here... THanks
I see the stickies with the mods, and I'm new to that stuff, looking to be able to update via SD, unless something else works as well or better. I have some knowledge, with the help of people here, was able to update and re install better firmware on a Rockchip RK3368 box... so if I have to use a PC for this little stick, I can figure that out too.
Thanks in advance everyone!
