Problem Child Nextbook Flexx NXW116QC264
I have a Windows 10 Nextbook 11" with detachable keyboard that locks up when I charge it's battery. Before charging the battery I power it off and close it (I leave the keyboard on it). When I return to it later in the evening the keyboard is lit and it will do nothing until I remove the back cover and disconnect the battery. When I reassemble it it is fine until I charge the battery again. I have disabled all Sleep settings in Windows which did not help. Does anyone have any information or suggestions for this????? is there a firmware upgrade which might help this?? If I can't find a fix I will remove the batteries and power it externally which would be better IMHO than throwing it away as I could find a use for it or even give it to someone who has no computer. It works well other than this problem.Tags: None
There are currently 1624 users online. 1 members and 1623 guests.
