I asked in another forum but they couldn't help me.
They said development for RK3188 stops with KK running on a 3.0.36+ kernel.
I have Lollipop
ro.build.fingerprint=FiiO/X7/rk3188:5.1.1/LMY48Y/FiiO02172023:user/release-keys
Unfortunately.
Boot is locked:
ro.allow.mock.location=0
ro.debuggable=0
Selinux is present.
CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x 00006000@0x00004000(kernel),0x00006000@0x0000a000( boot),
0x00010000@0x00010000(recovery),0x00020000@0x00020 000(backup),0x00040000@0x00040000(cache),
0x003FC000@0x00080000(userdata),0x00008000@0x0047C 000(metadata),0x00002000@0x00484000(kpanic),
0x00180000@0x00486000(system),-@0x00606000(user)
Kernel is present in kernel partition for 3.16_Beta, however bigger then 8 MB:
3.0.101+ #561 preempt 17 Feb 2017
Also it seems the tab uses eMMC:
# Android fstab file.
/dev/block/platform/emmc/by-name/system /system ext4 ro,noatime,nodiratime,noauto_da_alloc wait,resize
/dev/block/platform/emmc/by-name/cache /cache ext4 noatime,nodiratime,nosuid,nodev,noauto_da_alloc,di scard wait
/dev/block/platform/emmc/by-name/metadata /metadata ext4 noatime,nodiratime,nosuid,nodev,noauto_da_alloc,di scard wait
/dev/block/platform/emmc/by-name/userdata /data ext4 noatime,nodiratime,nosuid,nodev,noauto_da_alloc,di scard wait,encryptable=/metadata/key_file
/devices/platform/emmc/mmc_host/mmc /mnt/internal_sd vfat defaults voldmanaged=internal_sd:11,noemulatedsd
/devices/platform/rk29_sdmmc.0/mmc_host/mmc /mnt/external_sd vfat defaults voldmanaged=external_sd:auto
/devices/platform/usb20 /mnt/usb_storage vfat defaults voldmanaged=usb_storage:auto
/dev/block/zram0 none swap defaults zramsize=67108864
The update.img file is inside this archive, which contains the kernel, boot, fw, etc. FW 3.1.6_Beta.Zip
I used This to extract it. Downloaded RK3066_IMG_Mod_Tool.zip and renamed the update.img file "wendal.img" and dragged it inside the RK3066_IMG_Mod_Tool folder, then simply pressed "Runme" and then 1 to unpack, but you most likely already know all of this.
Here are the extracted files just in case MEGA
Let me also link an older FW that contains a RK3188Loader(L)_V2.15.bin and 3.0.36+ kernel inside along with other boot files that are also compatible with the newest FW, which are all Here
I tried using the CWM/TWRP generic which I got here to flash, but TWRP does not boot (maybe due to the 800x480 res), CWM does but it gives me these errors;
"E: Can't mount /cache/recovery/command
E: Can't mount /cache/recovery/log
E: Can't open /cache/recovery/log
E: Can't mount /cache/recovery/last_log
E: Can't open /cache/recovery/last_log
E: Can't open /dev/block/platform/ff0f0000.rksdmmc" errors and more.
None of them work yet sadly.
I can only root as of now, so no Viper4Android, no TWRP or CWM, or Xposed Installer. Would greatly appreciate some help.
