I have a Sunvell T95K, the multi colors box, that will not boot. It only shows the blue light in front of the unit. But won't boot. Is it bricked. Please help.
Sunvell T95K Pro will not boot. Only blue light on front.
Originally posted by sotxin View PostI was able to repair my T95K with the custom firmware listed on this site. Flash with Amlogic USB Burning Tool (chinagadgets). You will need an USB male to male cable. I had a hell of a time figuring this out GB support wasn't much help,
I had the same issue. I've updated the software withouot success.
i plug the powwer but nothing is done. a blue led only.
The problem was resolved after chanching my power supplier (5V - 2A) by a new one. the old one had a big noise, I think capacitor does not work correctly.
I advise to change your power supply. I've tested 5V-1A and it dont work. so you have to change by 2A.
There are currently 1535 users online. 0 members and 1535 guests.
