"Release" version firmware will be updated per month, you can download it click here
"Beta" version firmware will be updated per week, which is only for some enthusiasts who like to test some new problems and solved problems in advanced.
Egreat A5BD_EN_Firmware_20170221_v1.1.0.9.rar Beta
I. info
Firmware name A5BD_EN_Firmware_20170221_v1.1.0.9.rar
Updating Time: 21st, Feb 2017 Tuesday, at 9:35:13 a.m
MD5: 48BC69F2FAF6D65045B0D6C7E7C8D0EB
DownloadLink:
II. Recovery the firmware instructions
1.If your current firmware is v1.0.1.3, please force to recovery V1.1.0.7 firmware by USB and then update to V1.1.0.9 beta firmware.
2.If your current firmware is v1.0.1.5, please force to recovery V1.1.0.7 firmware by OTA and then update to V1.1.0.9 beta firmware.
3. You also can force to recovery the new V1.1.0.9 beta firmware directly, the force to recovery new version firmware instruction, please click here.
III.Changelog
ROM: 1.1.0.9 + 1.6.9
1.Poster-wall: New poster analysis engine
2.Poster-wall: Optimized poster wall load speed and Improve the display recognition rate
3.Poster-wall: Add DVD icon
4.Poster-wall: Improved text selected state display
5.Poster-wall:Folder containing .nomedia files will be automatically filtered
6.Player: Added support MVC 3D MKV format playback
7.Player: Added support DivX 5 format playback
8.Player: Added subtitle and OSD 3D depth adjustment
9.Player: Added auto playback function when power on(For videos in autoplay file of local play)
10.Player: Optimized buffering problem in network (Samba,NFS) playback
11.Player: Resolved some format video and audio out of sync problem
12.Player: Optimized the playback fluency when "Auto frame rate switch" is off
13.Player: Changed the tip position of 'volume setting is prohibited in passthrough mode'
14.Player: Solved lagging or stutter in some DTS-HD audio format
15.System: Fix Samba/NFS copy speed from PC to Egreat A5/A10
16.System: Support copy files over 1G from MAC or Linux system to A5/A10 shared folder
17.System: Revised some OSD language translation
18.System: Only standard IP address can be added in network share address
Source Egreat
