MXQ Pro+ 4K bricked and stucked on MBOX logo with yellow stripes
I have a MXQ Pro+ 4K box from China and due to playstore problems I had changed my build.prop and spoofed box in the name of a phone, which fixed problem and stopped playstore to update itself to TV version. But due to some Play Services problem (loosing internet again and again) I decided to restore backup of my original build.prop. But since then after restart the box is stucked to MBOX logo with yellow stripped screen and not going beyond that.
I tried to enter in to recovery by pressing reset button in AV port but nothing is happening. It simply boots to that yellow screen again. The decided to flash stock firmware using Amlogic USB Burning Tool 2.0.7 and 2.0.6. Tool recognises the box on HUB3-2 but gives error "[0x00101004]Erase bootloader/Lowper/Identify/Error result"
Now able to figure out how to proceed further. Please help.
