wetek play 2 #************************************************* ************************************************** ****** #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************* ************************************************** ********** #amlogic NEC remote factory_code = 0x5f5e0001 work_mode = 0 repeat_enable = 1 repeat_delay = 40 repeat_peroid = 39 release_delay = 121 debug_enable = 1 fn_key_scancode = 0x84 up_key_scancode = 0x50 down_key_scancode = 0x4b left_key_scancode = 0x4c right_key_scancode = 0x4d ok_key_scancode = 0x47 mouse_begin 0 0x4c 1 0x4d 2 0x50 3 0x4b mouse_end key_begin 0x02 116 # power 0x46 88 # 2nd power button (F12, ends WeTV) 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 580 # app_switch 0x77 373 # assist 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 97 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 402 # channel up 0x42 403 # channel down 0x4f 64 # * (mapped as f6) 0x82 388 # teletext 0x73 398 # red 0x74 399 # green 0x75 400 # yellow 0x76 401 # blue 0x67 165 # previous 0x79 168 # rewind 0x80 208 # fast fprward 0x81 163 # next 0x04 167 # record 0x2c 164 # play/pause 0x2b 166 # stop key_end repeat_key_begin 0x02 116 # power 0x46 88 # 2nd power button (F12, ends WeTV) 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 580 # app_switch 0x77 373 # assist 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 353 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 402 # channel up 0x42 403 # channel down 0x4f 64 # * (mapped as f6) 0x82 388 # teletext 0x73 398 # red 0x74 399 # green 0x75 400 # yellow 0x76 401 # blue 0x67 165 # previous 0x79 168 # rewind 0x80 208 # fast fprward 0x81 163 # next 0x04 167 # record 0x2c 164 # play/pause 0x2b 166 # stop repeat_key_end
We Need your Remotes
wetek play 2 #************************************************* ************************************************** ****** #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************* ************************************************** ********** #amlogic NEC remote factory_code = 0x5f5e0001 work_mode = 0 repeat_enable = 1 repeat_delay = 40 repeat_peroid = 39 release_delay = 121 debug_enable = 1 fn_key_scancode = 0x84 up_key_scancode = 0x50 down_key_scancode = 0x4b left_key_scancode = 0x4c right_key_scancode = 0x4d ok_key_scancode = 0x47 mouse_begin 0 0x4c 1 0x4d 2 0x50 3 0x4b mouse_end key_begin 0x02 116 # power 0x46 88 # 2nd power button (F12, ends WeTV) 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 580 # app_switch 0x77 373 # assist 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 97 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 402 # channel up 0x42 403 # channel down 0x4f 64 # * (mapped as f6) 0x82 388 # teletext 0x73 398 # red 0x74 399 # green 0x75 400 # yellow 0x76 401 # blue 0x67 165 # previous 0x79 168 # rewind 0x80 208 # fast fprward 0x81 163 # next 0x04 167 # record 0x2c 164 # play/pause 0x2b 166 # stop key_end repeat_key_begin 0x02 116 # power 0x46 88 # 2nd power button (F12, ends WeTV) 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 580 # app_switch 0x77 373 # assist 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 353 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 402 # channel up 0x42 403 # channel down 0x4f 64 # * (mapped as f6) 0x82 388 # teletext 0x73 398 # red 0x74 399 # green 0x75 400 # yellow 0x76 401 # blue 0x67 165 # previous 0x79 168 # rewind 0x80 208 # fast fprward 0x81 163 # next 0x04 167 # record 0x2c 164 # play/pause 0x2b 166 # stop repeat_key_endYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Guest
I received this same remote control with 2 different devices, although almost the same, so I'm listing both devices here, but just 1 picture and 1 remote.conf file.
Remote looks identical to previous post here: http://freaktab.com/forum/tv-player-...666#post633666
TV Box #1
Name: H96 Pro +
Brand: 4k Ultra HD TV Box S912
Vendor: Amazon.com - WESECH
Version: 8-core 3G/32GB ( unknown if DDR3 or DDR4 )
TV Box #2
Name: H96 Pro +
Brand: Alfawise
Vendor: Gearbest.com
Version: 8-core 3G/32GB DDR4 ( confirmed via opening case )
The /etc/remote.conf listed here is from the TV BOX #1 stock firmware above. Haven't checked to see if file is exact same on other boxes stock firmware, but will update this post if its different. I suspect its the same, since the remote is the exact same.
/etc/remote.conf
Code:#********************************************************************************************************* #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************************************************************************* #amlogic NEC remote work_mode = 0 repeat_enable = 1 repeat_delay = 130 repeat_peroid = 120 release_delay = 20 debug_enable = 1 fn_key_scancode = 0x15 left_key_scancode = 0x1c right_key_scancode = 0x48 up_key_scancode = 0x44 down_key_scancode = 0x1d ok_key_scancode = 0x1e pageup_key_scancode = 0x04 pagedown_key_scancode = 0x1b custom_begin factory_infcode = 0 factory_code = 0xfb040001 mouse_begin 0 0x1c 1 0x48 2 0x44 3 0x1d mouse_end key_begin 0x47 11 0x13 2 0x10 3 0x11 4 0x0F 5 0x0C 6 0x0D 7 0x0B 8 0x08 9 0x09 10 0x5C 97 0x51 65 0x49 14 0x06 130 0x14 131 0x44 103 0x1D 108 0x1C 105 0x48 106 0x53 125 0x45 104 0x19 109 0x16 102 0x52 119 0x05 122 0x59 123 0x1b 120 0x04 121 0x1A 116 0x0A 15 0x0e 113 0x15 63 0x1F 102 0x1e 132 0x07 133 0x12 134 0x54 135 0x02 136 0x4f 30 0x42 48 0x5d 46 0x4c 32 0x58 137 0x55 140 key_end repeat_key_begin 0x47 11 0x13 2 0x10 3 0x11 4 0x0F 5 0x0C 6 0x0D 7 0x0B 8 0x08 9 0x09 10 0x5C 97 0x51 65 0x49 14 0x06 130 0x14 131 0x44 103 0x1D 108 0x1C 105 0x48 106 0x53 125 0x45 104 0x19 109 0x16 102 0x52 119 0x05 122 0x59 123 0x1b 120 0x04 121 0x1A 116 0x0A 15 0x0e 113 0x15 63 0x1F 102 0x1e 132 0x07 133 0x12 134 0x54 135 0x02 136 0x4f 30 0x42 48 0x5d 46 0x4c 32 0x58 137 0x55 140 repeat_key_end custom_end custom_begin factory_infcode = 1 factory_code = 0xfb000001 mouse_begin 0 0x08 1 0x0b 2 0x17 3 0x0f mouse_end key_begin # < > dn up 0x0b 105 0x17 106 0x1b 108 0x0f 103 #ok back 0x1f 232 0x03 158 #menu home 0x02 125 0x01 102 #v- mute v+ 0x09 114 0x0e 113 0x06 115 #out in 0x04 130 0x05 131 #power fn del 0x0a 116 0x08 63 0x07 14 key_end repeat_key_begin # < > dn up 0x0b 105 0x17 106 0x1b 108 0x0f 103 #ok back 0x1f 232 0x03 158 #menu home 0x02 125 0x01 102 #v- mute v+ 0x09 114 0x0e 113 0x06 115 #out in 0x04 130 0x05 131 #power fn del 0x0a 116 0x08 63 0x07 14 repeat_key_end custom_end custom_begin factory_infcode = 2 factory_code = 0x40400001 mouse_begin 0 0x10 1 0x11 2 0x0b 3 0x0e mouse_end key_begin # 0 - 9 0x00 11 0x01 2 0x02 3 0x03 4 0x04 5 0x05 6 0x06 7 0x07 8 0x08 9 0x09 10 #del 0x0c 14 #recent apps 0x42 149 #web tv all_app 0x53 146 0x5b 147 0x54 145 #switch 0x44 888 # < > 0x10 105 0x11 106 0x0e 108 0x0b 103 #ok back 0x0d 232 0x42 158 #menu home 0x45 125 0x1a 102 #v- mute v+ 0x17 114 0x43 113 0x18 115 #|<< >| || >>| 0x1f 122 0x40 119 0x41 128 0x1e 123 #power fn 0x4d 116 0x47 63 key_end repeat_key_begin # 0 - 9 del space explorer 0x00 11 0x01 2 0x02 3 0x03 4 0x04 5 0x05 6 0x06 7 0x07 8 0x08 9 0x09 10 #del 0x0c 14 #recent apps 0x42 149 #web tv all_app 0x53 146 0x5b 147 0x54 145 #switch 0x44 888 # < > 0x10 105 0x11 106 0x0e 108 0x0b 103 #ok back 0x0d 232 0x45 158 #menu home 0x1d 125 0x1a 102 #v- mute v+ 0x17 114 0x43 113 0x18 115 #|<< >| || >>| 0x1f 122 0x40 119 0x41 128 0x1e 123 #power fn 0x4d 116 0x47 63 repeat_key_end custom_end custom_begin factory_infcode = 3 factory_code = 0xff000001 mouse_begin 0 0x47 1 0x15 2 0x46 3 0x16 mouse_end key_begin # < > dn up 0x0e 105 0x1a 106 0x02 108 0x03 103 #ok back 0x07 232 0x5c 158 #menu home 0x13 125 0x48 102 #mute v- v+ 0x01 113 0x58 114 0x0b 115 #power 0x14 116 key_end repeat_key_begin # < > dn up 0x0e 105 0x1a 106 0x02 108 0x03 103 #ok back 0x07 232 0x5c 158 #menu home 0x13 125 0x48 102 #mute v- v+ 0x01 113 0x58 114 0x0b 115 #power 0x14 116 repeat_key_end custom_end custom_begin factory_infcode = 4 factory_code = 0xfe010001 mouse_begin 0 0x51 1 0x50 2 0x16 3 0x1a mouse_end key_begin # < > dn up 0x51 105 0x50 106 0x1a 108 0x16 103 #ok back 0x13 232 0x19 158 #menu home 0x4c 125 0x11 102 #v- mute v+ 0x10 114 0x41 113 0x18 115 #power fn del 0x40 116 0x00 63 0x42 14 # 0 - 9 0x01 11 0x4e 2 0x0d 3 0x0c 4 0x4a 5 0x09 6 0x08 7 0x46 8 0x05 9 0x04 10 #|<< play stop >>| << >> 0x59 122 0x5a 119 0x52 128 0x58 123 0x55 121 0x54 120 #zoom photo music file 0x45 130 0x49 144 0x0a 143 0x48 148 # 0x4d 146 0x0e 146 0x0f 145 #setup search subtitle audio 0x43 142 0x03 127 0x06 149 0x44 150 key_end repeat_key_begin # < > dn up 0x51 105 0x50 106 0x1a 108 0x16 103 #ok back 0x13 232 0x19 158 #menu home 0x4c 114 0x11 115 #v- mute v+ 0x10 125 0x41 113 0x18 102 #power fn del 0x40 116 0x00 63 0x42 14 # 0 - 9 0x01 11 0x4e 2 0x0d 3 0x0c 4 0x4a 5 0x09 6 0x08 7 0x46 8 0x05 9 0x04 10 #|<< play stop >>| << >> 0x59 122 0x5a 119 0x52 128 0x58 123 0x55 121 0x54 120 #zoom photo music file 0x45 130 0x49 144 0x0a 143 0x48 148 # 0x4d 146 0x0e 146 0x0f 145 #setup search subtitle audio 0x43 142 0x03 127 0x06 149 0x44 150 repeat_key_end custom_end custom_begin factory_infcode = 5 factory_code = 0xfd020001 mouse_begin 0 0x5d 1 0x5c 2 0x06 3 0x1f mouse_end key_begin # < > dn up 0x5d 105 0x5c 106 0x1f 108 0x06 103 #ok back 0x1e 232 0x1b 158 #menu home 0x58 125 0x59 102 #v- mute v+ 0x16 114 0x43 113 0x44 115 #power fn del 0x1a 116 0x0b 63 0x0c 14 #play << >> 0x55 119 0x54 121 0x17 120 #|<< >>| 0x14 122 0x1c 123 # 0 - 9 0x00 11 0x01 2 0x02 3 0x03 4 0x04 5 0x05 6 0x1d 7 0x07 8 0x08 9 0x09 10 #file tv web set 0x53 148 0x12 147 0x57 146 0x52 142 #PHOTO PAGE_UP PAGE_DOWN MUSIC 0x10 144 0x18 61 0x19 62 0x11 143 #info language miracast wifi 0x42 152 0x13 192 0x41 193 0x15 194 key_end repeat_key_begin # < > dn up 0x5d 105 0x5c 106 0x1f 108 0x06 103 #ok back 0x1e 232 0x1b 158 #menu home 0x58 125 0x59 102 #v- mute v+ 0x16 114 0x43 113 0x44 115 #power fn del 0x1a 116 0x0b 63 0x0c 14 #play << >> 0x55 119 0x54 121 0x17 120 #|<< >>| 0x14 122 0x1c 123 # 0 - 9 0x00 11 0x01 2 0x02 3 0x03 4 0x04 5 0x05 6 0x1d 7 0x07 8 0x08 9 0x09 10 #file tv web set 0x53 148 0x12 147 0x57 146 0x52 142 #PHOTO PAGE_UP PAGE_DOWN MUSIC 0x10 144 0x18 61 0x19 62 0x11 143 #info language miracast wifi 0x42 152 0x13 192 0x41 193 0x15 194 repeat_key_end custom_end
TX 5 Pro, Remote: http://imgur.com/GXalUOb
Code:#********************************************************************************************************* #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************************************************************************* #amlogic NEC remote factory_code = 0x40400001 work_mode = 0 repeat_enable = 1 repeat_delay = 130 repeat_peroid = 120 release_delay = 20 debug_enable = 1 fn_key_scancode = 0x47 left_key_scancode = 0x10 right_key_scancode = 0x11 up_key_scancode = 0x0b down_key_scancode = 0x0e ok_key_scancode = 0x0d mouse_begin 0 0x10 1 0x11 2 0x0b 3 0x0e mouse_end key_begin 0x43 113 #MUTE 0x01 2 #No.1 0x02 3 #No.2 0x03 4 #No.3 0x04 5 #No.4 0x05 6 #No.5 0x06 7 #No.6 0x07 8 #No.7 0x08 9 #No.8 0x09 10 #No.9 0x00 11 #N0.0 0x45 125 #MENU 0x42 1 #BACK/EXIT 0x0d 97 #ENTER/OK 0x10 105 #LEFT 0x0b 103 #UP 0x0e 108 #DOWN 0x11 106 #RIGHT 0x18 115 #VOL+ 0x17 114 #VOL- 0x0c 14 #DEL 0x4d 116 #Power 0x1a 102 #home 0x53 119 #media_pause 0x44 52 #period 0x1e 123 #MEDIA_NEXT 0x1f 122 #MEDIA_PREVIOUS 0xf1 140 #F10/factory_test 0x54 150 #setting 0x57 151 #PROG_YELLOW/EXPLORER 0x5b 152 #PROG_BLUE/MUSIC 0x5c 153 #ALLAPP 0x5d 154 #MEDIAPLAY key_end repeat_key_begin 0x43 113 #MUTE 0x01 2 #No.1 0x02 3 #No.2 0x03 4 #No.3 0x04 5 #No.4 0x05 6 #No.5 0x06 7 #No.6 0x07 8 #No.7 0x08 9 #No.8 0x09 10 #No.9 0x00 11 #N0.0 0x45 125 #MENU 0x42 1 #BACK/EXIT 0x0d 97 #ENTER/OK 0x10 105 #LEFT 0x0b 103 #UP 0x0e 108 #DOWN 0x11 106 #RIGHT 0x18 115 #VOL+ 0x17 114 #VOL- 0x0c 14 #DEL 0x4d 116 #Power 0x1a 102 #home 0x44 52 #period 0x1e 120 #MEDIA_FAST_FORWARD 0x1f 121 #MEDIA_REWIND 0x54 150 #setting 0x57 151 #PROG_YELLOW/EXPLORER 0x5b 152 #PROG_BLUE/MUSIC 0x5c 153 #ALLAPP 0x5d 154 #MEDIAPLAY repeat_key_end
OTT TV BOX YOKA TV KB2 PRO
# SW MODE:
# REG
#amlogic NEC remote
#factory_code = 0xfb040001 #amlogic rel
factory_code = 0xff000001 #video striong
work_mode = 0
repeat_enable = 0
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 1
fn_key_scancode = 0x12
left_key_scancode = 0x5a
right_key_scancode = 0x1b
up_key_scancode = 0x06
down_key_scancode = 0x16
ok_key_scancode = 0x1a
pageup_key_scancode = 0x55
pagedown_key_scancode = 0x15
mouse_begin
0 0x5a
1 0x1b
2 0x06
3 0x16
mouse_end
key_begin
#video strong
0x59 116 #power
0x19 113 #mute
0x0e 130 #info
0x0d 102 #home
0x51 14 #del
0x12 134 #mouse
0x4d 137 #epg //没找到
0x11 237 #dtv
0x45 125 #menu
0x05 1 #exit
0x06 103 #up
0x5a 105 #left
0x1a 97 #enter
0x1b 106 #right
0x16 108 #down
0x55 104 #page+
0x15 109 #page-
0x52 2 #1
0x50 3 #2 //没ç€åˆ°åŒ¹é…çš„
0x10 4 #3
0x13 115 #vol+
0x56 5 #4 //没ç€åˆ°åŒ¹é…çš„
0x54 6 #5
0x14 7 #6
0x17 114 #vol- //没ç€åˆ°åŒ¹é…çš„
0x4e 8 #7 //没ç€åˆ°åŒ¹é…çš„
0x4c 9 #8
0x0c 10 #9
0x0f 11 #0
0x4a 121 #fr //没ç€åˆ°åŒ¹é…çš„
0x48 120 #ff
0x08 122 #prev
0x0b 123 #next
0x46 119 #play/pause //没ç€åˆ°åŒ¹é…çš„
0x44 128 #stop
0x04 56 #pvr
0x07 132 #repeat
0x42 134 #red
0x40 133 #green //没ç€åˆ°åŒ¹é…çš„
0x00 131 #yellow //没ç€åˆ°åŒ¹é…çš„
0x03 140 #blue //没ç€åˆ°åŒ¹é…çš„
0x1f 212 #fav
0x58 261 #app
0x18 70 #browser //没ç€åˆ°åŒ¹é…çš„
0x0e 136 #audio //没ç€åˆ°åŒ¹é…çš„
0x09 135 #subtitle
0x60 160 # red
0x61 161 # green
0x62 162 # yellow
0x63 163 # blue
0x02 130 #info
0x01 136 #audio //没ç€åˆ°åŒ¹é…çš„
0x21 52 #.
0x22 127 #search
0x64 164 #pvr list
key_end
repeat_key_begin
0x47 11
0x13 2
0x10 3
0x11 4
0x0F 5
0x0C 6
0x0D 7
0x0B 8
0x08 9
0x09 10
0x5C 97
0x51 65
0x49 14
0x06 130
0x14 131
0x44 103
0x1D 108
0x1C 105
0x48 106
0x53 125
0x45 104
0x19 109
0x16 102
0x52 119
0x05 122
0x59 123
0x1b 120
0x04 121
0x1A 116
0x0A 15
0x0e 113
0x15 63
0x1F 102
0x1e 132
0x07 133
0x12 134
0x54 135
0x02 136
0x4f 30
0x42 48
0x5d 46
0x4c 32
0x58 137
0x55 140
0x21 52
0x22 127 #search
repeat_key_end
Originally posted by Dandroid534 View PostDandroid534's remote.conf
Note: I can't get the keys to work to cycle through number/letter/letter, if anyone could give that input.. it would make my day
Note2: getting record to work would also be awesome (for kodi)
Code:#************************************************* ************************************************** ****** # this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************* ************************************************** ********** #amlogic NEC remote # based on /system/usr/keylayout/Vendor_0001_Product_0001.kl factory_code = 0x5f5e0001 work_mode = 0 repeat_enable = 1 repeat_delay = 40 repeat_peroid = 39 release_delay = 121 debug_enable = 1 fn_key_scancode = 0x84 up_key_scancode = 0x50 down_key_scancode = 0x4b left_key_scancode = 0x4c right_key_scancode = 0x4d ok_key_scancode = 0x47 mouse_begin 0 0x4c 1 0x4d 2 0x50 3 0x4b mouse_end key_begin 0x02 116 # power 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 145 # app_switch 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 97 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 61 # channel up 0x42 62 # channel down 0x4f 227 # * 0x82 149 # teletext 0x73 144 # red 0x74 143 # green 0x75 155 # yellow 0x76 70 # blue 0x67 122 # previous 0x79 121 # rewind 0x80 120 # fast fprward 0x81 123 # next 0x04 153 # record 0x2c 119 # play/pause 0x2b 128 # stop key_end repeat_key_begin 0x02 116 # power 0x10 113 # volume mute 0x22 2 # 1 0x23 3 # 2 0x24 4 # 3 0x25 5 # 4 0x26 6 # 5 0x27 7 # 6 0x28 8 # 7 0x29 9 # 8 0x30 10 # 9 0x71 14 # delete 0x21 11 # 0 0x72 58 # caps lock 0x48 127 # menu 0x03 102 # home 0x61 158 # back 0x83 145 # app_switch 0x77 373 # assist 0x50 103 # up 0x4b 108 # down 0x4c 105 # left 0x4d 106 # right 0x47 353 # ok 0x44 115 # volume up 0x43 114 # volume down 0x41 61 # channel up 0x42 62 # channel down 0x4f 227 # * 0x82 149 # teletext 0x73 144 # red 0x74 143 # green 0x75 155 # yellow 0x76 70 # blue 0x67 122 # previous 0x79 121 # rewind 0x80 120 # fast fprward 0x81 123 # next 0x04 153 # record 0x2c 119 # play/pause 0x2b 128 # stop repeat_key_end
K12 Pro
Tanix TX8
Tanix TX8 MAX
Vorke Z6 and others
Both remote are interchangeable and the numbers are working in all devices
First the remote with numeric keypad
# SW MODE:
# REG
#amlogic NEC remote
work_mode = 0
repeat_enable = 1
repeat_delay = 130
repeat_peroid = 120
release_delay = 20
debug_enable = 1
#fn_key_scancode = 0x15
#left_key_scancode = 0x1c
#right_key_scancode = 0x48
#up_key_scancode = 0x44
#down_key_scancode = 0x1d
#ok_key_scancode = 0x5c
#pageup_key_scancode = 0x04
#pagedown_key_scancode = 0x1b
custom_begin
factory_infcode = 1
factory_code = 0x7f800001
fn_key_scancode = 0x52
left_key_scancode = 0x25
right_key_scancode = 0x27
up_key_scancode = 0x26
down_key_scancode = 0x28
mouse_begin
0 0x25
1 0x27
2 0x26
3 0x28
mouse_end
key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 97
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 63
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 288
0x44 14
0xbd 122
0xbb 123
0x09 292
0x11 289
0x54 290
0x4f 291
0xbc 140
0x40 67
0x41 177
0x42 178
key_end
repeat_key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 97
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 63
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 288
0x44 14
0xbd 122
0xbb 123
0x09 292
0x11 289
0x54 290
0x4f 291
0xbc 140
0x40 67
0x41 177
0x42 178
repeat_key_end
custom_end
custom_begin
factory_infcode = 2
mouse_begin
0 0x10
1 0x11
2 0x0b
3 0x0e
mouse_end
key_begin
0x43 113
0x17 114
0x18 115
0x10 105
0x0b 103
0x11 106
0x0e 108
0x0d 97
0x42 158
0x1a 102
0x4d 704
0x45 139
0x47 63
0x0c 14
0x01 2
0x02 3
0x03 4
0x04 5
0x05 6
0x06 7
0x07 8
0x08 9
0x09 10
0x00 11
key_end
repeat_key_begin
0x43 113
0x17 114
0x18 115
0x10 105
0x0b 103
0x11 106
0x0e 108
0x0d 97
0x42 158
0x1a 102
0x4d 704
0x45 139
0x47 63
0x0c 14
0x01 2
0x02 3
0x03 4
0x04 5
0x05 6
0x06 7
0x07 8
0x08 9
0x09 10
0x00 11
repeat_key_end
custom_end
Second the remote without numeric keypad
# SW MODE:
# REG
#amlogic NEC remote
work_mode = 0
repeat_enable = 1
repeat_delay = 130
repeat_peroid = 120
release_delay = 20
debug_enable = 1
mouse_begin
0 0x10
1 0x11
2 0x0b
3 0x0e
mouse_end
key_begin
0x43 113 #MUTE
0x01 2 #No.1
0x02 3 #No.2
0x03 4 #No.3
0x04 5 #No.4
0x05 6 #No.5
0x06 7 #No.6
0x07 8 #No.7
0x08 9 #No.8
0x09 10 #No.9
0x00 11 #N0.0
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 115 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x44 52 #period
0x54 150 #setting
0x5c 153 #ALLAPP
0x5d 154 #MEDIAPLAY
0x5e 159 #KODI
key_end
repeat_key_begin
0x43 113 #MUTE
0x01 2 #No.1
0x02 3 #No.2
0x03 4 #No.3
0x04 5 #No.4
0x05 6 #No.5
0x06 7 #No.6
0x07 8 #No.7
0x08 9 #No.8
0x09 10 #No.9
0x00 11 #N0.0
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 115 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x44 52 #period
0x54 150 #setting
0x5c 153 #ALLAPP
0x5d 154 #MEDIAPLAY
0x5e 159 #KODI
repeat_key_end
Onkyo code for the Khadas VIM2 LibreELEC?
Hey!
I have the onkyo 636 receiver and I installed LibreELEC on the Khadas VIM2 device
And I want to control it with the receiver remote and for that I need a control code for the receiver remote
Does anyone know the code?
If this is not the place to open this post then please direct me to the correct forum
Can someone tell me how to get ahold of these files in Android 9 pie? I went searching for remote.conf file in normal place but has moved in Android 9 pie. I have SEVERAL TV boxes with remotes I need to know how to change these remote settings, and would happily contribute back to the discussion with my remote codes. Any assistance much appreciated.
I have Q+ (Allwinner H6), 8K (S905x2), and X96air (S905x3).
Hi there,
We Need your Help making a data base of Remote controls We are going to ask all users to help us get a running list that can be used to help change the remote
I would like to send my control configuration but I don't know how to get or extract it? Is there any tutorial about it at forum?
Regards
There are currently 1856 users online. 2 members and 1854 guests.
