while I do not have any clue on how to make Bluetooth working on this box using a USB dongle
X96 Magendanz ROM with remote fix.
Hi ppl, Just got new X96 box and have weird issue when try to use remote or bluetooth mouse screen flickering and going black screen and come back again..
Edit: problem solved the power adaptor is sick one! who have same problem please try to change power adaptorLast edited by eltdesign; 04-12-2017, 14:30.
Originally posted by scooter2014 View PostHad a Wierd issue on a x96 box... My two gone now but got another one to test a problem and ended up with the same issue as 2 other users on Freaktab.. flashing firmware box reverts to 1/8 gig device was orginally 2/16 now i have been able to get it back to a 2/8 device and check with RAM check and its verified as correct nan size now trying to find out what happened re internal storage Wierd stuff.....
I only found one rom that switch it back to 2 gig but 2/8 not 2/16 (dont know if i had back chip because soder was horrible on the nan. I heated and hot so all joints even not touching. Bit think emmc different set up I check i have to re flash it again so i post once i dig through and find for box i have here.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostI only found one rom that switch it back to 2 gig but 2/8 not 2/16 (dont know if i had back chip because soder was horrible on the nan. I heated and hot so all joints even not touching. Bit think emmc different set up I check i have to re flash it again so i post once i dig through and find for box i have here.
I'd be much pleased if you were able to find which firmware performed the miracle to bring your box back to 2GB RAM, regardless of the NAND size.
Originally posted by adhots View Post
Can u share the rom with switch to 2/8gb?
https://www.dropbox.com/s/h9pcjoal5z...mware.img?dl=0
Originally posted by jfive74 View Post
He posted it in other thread. On same page there is a rooted version. I tried it and it does restore 2gb but I believe boards are fake.
I just flashed that ROM and the system reads both on android and CPU-Z 2GB of RAM and around 14GB of storage.
The problem is that it REALLY seems like this box has FAKE RAM.
I checked the board. It has four k4W2G1646P-HC12 SAMSUNG 513 chips, two on each side of the board.
But after flashing the ROM that "brings back" the 2GB of RAM, I ran a "Fill RAM memory" app, and it crashes around 47% of filling, what makes me believe the real memory available is around 1GB.
So this box really seems to have FAKE RAM designed through firmware coding.
I'll return this damn thing for a refund.
There are currently 2207 users online. 5 members and 2202 guests.
