I need some ore help.
Im trying to flash my H96 pro via usb cable. (Male to Male usb plugged into usb port closest to power supply as advised)
When I reset the unit by holding in the reset button the unit boots i hear it connect to my pc then immediately disconnects and loads the TWRP menu.
How do I get it to stay connected to my pc so I can flash the new rom?
Thanks in advance.
