VONTAR Z5 SUPERMAX
    VONTAR Z5 SUPERMAX
    "This is another S912 based box - looks to be identical to the Mecool BB2 and the YOKA KB2. The stock firmware isn't great or pretty so I've been looking at other ROM/Firmware as I hear they can be cross compatible."
    - Amlogic S912 64 bit Octa core ARM Cortex-A53 CPU up to 2 GHz
    - GPU: ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
    - DDRIII 2GB, eMMC Flash 16GB
    - Android 6.0 marshmallow
    - Support HDR10 and HLG HDR
    - Support VP9 up to 4Kx2K@60fps
    - Support to H.265 HEVC up to 4Kx2K@60fps
    - Max 4Kx2K @60 Resolution
    - 2.4G/5GHz Dual Wifi, Wifi Antenna with Superior Signal Reception
    - Support 1000M Gigabit LAN, Bluetooth 4.0
    - KODI Pre-installed and Play Perfect
    - Famous Apps Pre-installed and play perfect.
    - Support Firmware OTA
    Firmware Recovery By Microsd card!
    or
    or
    or
    Because i found so hard, i upload to all you guys!
