Okay, I'm finally at my wit's end with this unit. I have an all black MXQ box that came in the traditional OTT cardboard box--1GB RAM, 8GB storage, board version s805q_v2.0
I've posted in the site's repository the two SD card based ROMs that work on my box. Here are my current issues:
1. Despite having working wifi, I still have an issue with the constant blue LED, whether the box is on or not.
2. I cannot sideload/dual boot OpenElec, LibreElec, EmbER or anything from SD or USB. This is one area I really want to resolve as it appears to be the only means to help me reclaim most, if not all, of the boxes RAM.
3. I've yet to find an .IMG file that works completely using the usb burn tool(tried several tool versions). 105k thru 112k load successfully, but with "spill-over"/"running paint" video resolution, as does some of the OTA .zip updates
4. I learned oh so late that certain ROM types need to be applied in a certain order as some are partial and some are complete. At one point, I was able to load an OTA update from the EntertainmentBox site, trying to find the best load for this box. But now, with either of the 2 known working ROMs for my board, I can no longer load that Ebox update. I've tried 10 different ROMs but I'm flustered at this point as to which one I should start with as a base and which OTAs should subsequently be applied as test updates
Can someone guide me in the right direction?
