I managed to create mo123 lollipop rom 1.7b to boot from SD card.
The image was created in a Sandisk Extreme Pro 32GB.
You can find it here https://www.dropbox.com/s/cvlgncpxk0...kup17b.7z?dl=0
Unzip it with 7zip
Download and Install HDD Raw copy from here http://hddguru.com/software/HDD-Raw-Copy-Tool/
Then select in the tool as source the file backup17b.imgc and destination your SD card.
After the tool finishes then extract your card from your pc. Shutdown the 3288 Device. Insert the card and power on.
In case the device boots from your internal eMMC then you have to flash the below bootloader
https://www.dropbox.com/s/tnxaflb1re...17.02.bin?dl=0
or you can use the Android Tools from this link https://www.dropbox.com/s/gos3fmloe1...e_v2.3.7z?dl=0.
Start AndroidTool.exe then Right click inside the box (1st ta Download Image) and select Load Config.
Select onlyloader.cfg and open.
Flash your device (click Run in the same tab) and reboot.
Special thanks go to
mo123 for creating very good Roms
linuxium for creating the scripts
