don't try to flash. May be anyone cant try it?
SCISHION V88 mini II TV Box - 2 + 8GB
Hi there,
thanks for sharing, I have tried rk3229_6.0_box_MX4M_RTL8723CS_RTL8703BS_SpecTek_fl ash-update_20170617.
I did not notice any difference with rk3229_6.0_box_MX4V_RTL8723CS_RTL8703BS_SpecTek_fl ash-update_20170518 , what should it bring (any what´s new info)?
My problem with the box is actually something else:
It was announced support video messaging apps (also in initial release), I have bought the box especially for my granddad as a “video telephony” device. So far the box (and remote control) has no build-in camera or mic and no AV inputs, we are forced to use external one, connected per USB.
I have not succeeded to get any video messaging app to work. At the same time in “voice search” any mic always works correctly.
Tried apps:
Skype (6.25.99.11.07 (preinstalled), 7.46.0.596 (actual version from Google Play) and dozen other Skype variants), Google Hangouts, Viber, Wire, ICQ
Tried Webcams:
Microsoft Lifecam HD-5000, Logitech C270, Trust Exis Webcam, Trust SpotLight Webcam Pro, some noname cams , USB audio dongle (china made “5.1 3D sound”), just simplest china USB mic.
Tried firmwares:
Android 5.1 rk3229_update_2017021017
Android 6.0.1 rk3229_6.0_box_MX4V_RTL8723CS_RTL8703BS_SpecTek_fl ashupdate_20170518.img
Android 6.0.1 rk3229_6.0_box_MX4M_RTL8723CS_RTL8703BS_SpecTek_fl ash-update_20170617.img
Tried “soft tweaks ” (OK Goggle always disabled in settings):
add in bild.prop:
usb.audio.cap.device=pcmC3D0c
audio.input.active=AUDIO_CODEC
play around audio_policy.conf and mixer_paths in /etc
play with SoundAbout v2.7.0.1
Always same issue: no chance to get sound (camera mic or separately connected mic) and video together! On some apps (for example in preinstalled obsolete Skype) I can reach a state with VERY distorted sound during “just audio call”, even this distorted sound is disappearing if I click ”turn on video”. No sound in any app if I try to make “video call”. I suspect this to be a generic android/firmware problem.
-Looks like after plugging, microphone is always detected correctly in /dev/snd/ as pcmC3D0c.
-Looks like messaging apps are always forced to use the device´s internal microphone, just ignoring others.
I am almost exhausted, could you guys share (if somebody succeeded) following:
-USB hardware (mic webcam , soundcard etc.)
-video messaging app and version
-firmware in Box
Any other advice how to get videocalls working on device greatly appreciated.
New firmware out rk3229_6.0_MX4M_V88_MINI_II_RTL8723cs_zhongx_20170 712_V013_Spectek.zip here's the link https://yadi.sk/d/hhXNm07I3Lypob .
Originally posted by anthony96New firmware out rk3229_6.0_MX4M_V88_MINI_II_RTL8723cs_zhongx_20170 712_V013_Spectek.zip here's the link https://yadi.sk/d/hhXNm07I3Lypob .
Sent from my Redmi 4A using Tapatalk
I have 3 of these bixs and they all do the same
On some apps not all apps when I close it the screen will go 1/3 size (black bar, tv box screen, then black bar) to get full screen again I find opening kodi will force full screen.
Or
Other times the screen will rotate sideways and all mouse features and remote features are opposite. Left is right down is up.
Has anyone noticed this?
I am hoping a different firmware will fix
There are currently 1867 users online. 1 members and 1866 guests.
