power supply
    power supply
    hi,
    i never used the standard power supply that came with the cx-919
    in stead i use this one:
    (sku-199881)
    i don't have wifi or bluetooth problems, and saw only once the nand blanc issue (right after flashing finless 1.4 4.2.2).
    running the device 24/7 on a touchscreen in the kitchen, and no reboots jet or problems..
    my old ug802 did seem to preform better with this power supply.
    Not trying to sell stuff, just giving a hint/tip.....
    regards,
    Mark
    Thanks for the info...Where can I buy one in USA?
      i bought it at dx.com search number sku199881
        http://dx.com/p/5v-3a-switching-powe...40v-15w-199881
        Thanks for the link. Can you let us know where/what cables you will be using with this power adapter.
        I'm concerned that part of my system crashes are due to the quality of the shipped power plug For this reason, I will be docking the stick to the Measy U2C-D dock which draws it's power from a D-Link 5V/3A power plug (2.5mm barrel tip).
        smithmal
          a standard micro usb.
          cut off het normal usb plug and used the red V+ and black V-
            Thanks for the response. What was the reason you decided not to use the stock charger?
            smithmal
              Re: power supply
              As in many topics is said, that The standard psu's are not verry stable.
              Heavy apps, and USB devices give An unstable unit. Because of power shortage. So searched for an other power supply.
              Verstuurd van mijn GT-I8190 met Tapatalk
                Re: power supply
                Yes he is right, in my fitst rk3066 (mk808b) the stock psu only give me problems, freezes and random reboots or crash, with a good psu the stick started to work great.
                In my qx1 I didn't test the stock psu.
                leolas
                My devices:
                Gearbest.com)
                  size
                  Hey,
                  what are the measurements on this Powersupply? Need to know if i can fit it behind my mirrortv..
                  Thanks!
                    Re: power supply
                    9,3 x 4,3 x 2,7 cm
                    3.66 x 1.69 x 1.06 inch
