mk809III
mk809III
As I trying to put firmware to my MK809 III Rockchip RK3188 3188 Quad Core Cortex A9 MK809III MINI Androind 4.2 PC TV Stick 2GB RAM 8GBROM 1.8GHz (Photo) the reset button not work any more.I push it to connect to my pc(windows 7) and nothing happens.Is anybody knows something to help me?Tags: None
Originally posted by iord2002 View PostAs I trying to put firmware to my MK809 III Rockchip RK3188 3188 Quad Core Cortex A9 MK809III MINI Androind 4.2 PC TV Stick 2GB RAM 8GBROM 1.8GHz (Photo) the reset button not work any more.I push it to connect to my pc(windows 7) and nothing happens.Is anybody knows something to help me?
I had to angle mine slightly till i could feel the button press. Also if your still having issues, it was pretty easy to open and check the switch.
To open i just used a credit card and gently ran it around the edge and it easily same apart.
By i did flash mine and lost BT and WIFI. Maybe you should check your chip set first.
Originally posted by corruptsector View PostI got mine today and make sure you are pressing in the hole on the side, not the one on the top.
There are currently 2493 users online. 2 members and 2491 guests.
