Factory Stock Firmware request for MXQ Pro Model G10SX 2/16GB (Front Clock Display)
Hi everyone. I have been searching the net for a while now looking for the factory stock firmware for my MXQ Pro S905x model G10SX. Does anyone have a back up image of the factory firmware or a link to where I can download MXQ's pro currently shipping version of firmware?Tags: None
Now got firmware update for G10SX
G10SX Update by SD Card
1. Copy the 3 files to the SD card
2. In the case of no connect the power, insert the SD card, and then use a small stick stabbed into the AV jack, hold down the upgrade button inside
3. While holding down the upgrade button, connect the power supply until you see the upgrade progress bar on your TV (indicating that the system has started auto-upgrade), then release the upgrade button and wait for the upgrade to complete. Do not disconnect the power supply.
4.After the upgrade, the system will automatically restart。
There are currently 4270 users online. 1 members and 4269 guests.
