Beelink GT1 Amlogic S912 Chip EMMC 16G
    Beelink GT1 Amlogic S912 DDR3 2G, eMMC 16G up to 32G, remote upgrade, now with no Protective Film
    Beelink GT1 is now can buy as below:
    •Essentials
    Status Launched
    Launch Date August , 2016
    Product model GT1
    Dimension 96*96*16mm
    Processor Number Amlogic S912
    System Config
    OS Android 6.0
    Language Multi -language
    CPU Amlogic S912 Octa Core ARM Cortex-A53 CPU up to 2GHz(DVFS)
    GPU ARM Mali-T820MP3 GPU up to 750MHz(DVFS)
    RAM DDR3 2GB
    ROM Onboard eMMC Flash 16GB/32GB
    Ethernet 1000Mbps LAN
    WIFI IEEE 802.11a/b/g/n/ac,2.4G+5.8G+ac
    BT BT 4.0
    Antenna Built-in antenna for WIFI
    Expand Memory Micro SD Card (Maximum support 64GB)
