recommendations for an android box
Hello faolteam, Welcome to Freaktab.
Your question is a bit too broad. It may help if you state what your primary use for the box will be.
Also, price range and things that are important to you like, gigabit or 10/100 LAN, dual-band or single band WiFi,etc.
I don't make recommendations, but will say this. Though not a rule, all else being equal, 2GB RAM or better, is always best if you are looking for spirited overall performance. You may already know, boxes usually are listed as RAM/Storage, for instance, 2GB/8GB is 2GB RAM and 8GB Storage, etc.
If you are new to the Android TV box world, you may want to read this guide.
Good luck.
Thanks Riscy , im just looking for a reliable machine can watch a few sports channels dont need mad memory preferably something that updates itself i had a minix 5
Im having a prob with a minix 5 just comes on with the logo nothing happens any ideas , the guy i bought it of wasn't realy interested.
was looking at the MX Q PRO or the T95N_- MINI MX
Thanks Guys
Originally posted by faolteamrecommendations for an android box if i need to get one just looking for a reliable fast box dont need mad memory cheers
In my experience stay away from goobangdoo and leelbox they all have garbage firmware. I'd go with tronsmart personally. Just my opinion though.
Sent from my LG-H873 using Tapatalk
There are currently 2798 users online. 2 members and 2796 guests.
