/system/media/kodi.zip found in Dolamee D5 Android 6.0.1 stock firmware.
    Hey, Looking for a little guidence here.
    I have been digging into the stock firmware just updated and was looking to customize it (remove bloat add FTMC get rid of the stock launcher add widevine DRM you know the normal)
    While looking around I found a Kodi.zip file in the /system/media folder of the system.img.
    I assume this file is unzipped durring the first run.
    After making all of my modifications I added a kodi.zip file with everything FTMC needed to be setup the way I like, but it was never unzipped)
    Any idea what prompts this file to be unzipped?
    Thanks in advanced
