MINI ONE TV Box
    MINI ONE TV Box
    RK3229 Quad Core Cortex-A7 CPU Android
    Model: MINI ONE
    Type: TV Box
    System: Android 6.0
    Processor: RK3229
    CPU: ARM Cortex-A7
    Core: Quad Core
    GPU: Mali-400
    RAM: 1G
    RAM Type: DDR3
    ROM: 8G
    Max. Extended Capacity: 32G
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,DTS,FLAC,MP3,OGG,RM,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,RJ45,TF card,USB2.0
    Antenna: Yes
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: Miracast
    External Subtitle Supported: Yes
    HDMI Function: CEC
    RJ45 Port Speed: 100M
    System Bit: 32Bit
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA batteries
    Product weight: 0.0950 kg
    Package weight: 0.4090 kg
    Product size (L x W x H): 7.70 x 7.70 x 1.70 cm / 3.03 x 3.03 x 0.67 inches
    Package size (L x W x H): 18.80 x 13.55 x 5.75 cm / 7.4 x 5.33 x 2.26 inches
    Package Contents: 1 x MINI ONE TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x English User Manual
    Gearbest
    I got one. Device dropped to Android Recovery. Vendoк get me update.zip for updating, but update procedure doesn't start after reboot i still see android recovery menu
    How i can reflash my brick?
      Anyone can help me or not?
      • trebor
        trebor commented
        Editing a comment
        Don't have this unit...
        Did they send you a zip file or an .img ?
        if zip copy to USB or SD
        Read screen, point to path should update.....
        or ask the Vendor how to use is the best i can do at this stage
      They send a zip file, i rename file into update.zip copy that to sd, push reset button on bottom side, system boot, but only in recovery mode. i can't choose boot from sd....
      How to fix that?
      Thx
        Do you see a menu with choice....
        May need to plug in mouse or keyboard to move to update from zip
          There's no such menu:
            Check the zip file some times is double packed (yes zip inside a zip.) unpack it and see whatbis inside it. If three files unpack to a sd card and try again.
              Checked twice. Everything OK with zip, no double packed
              In system recovery menu I don’t have a string apply update from EXT. how I can enable this string?
