Android 5 or 6 for S83B S802B?
    Hello.
    is it possible to get Android 5 or 6 on this box?:
    Mbox S83B S802B 2GB/16GB Mali 450 DTS Finless Rom 2.1 Android 4.4.2
    Thank you.
    Originally posted by anavrin74 View Post
    Hello.
    Thank you.
    Most likely not
    That box is probably not even sold anymore and abandoned long ago by the manufacturer.
      Your best option is:
      libreelec 7 is kodi 16.1 / libreelec 8 is Kodi 17.1 RC
      I did the same on my s802-h Vega
      Cheers
        Thanks. Can you please link me a guide how to install Version 8 on the S82 to boot from SD? I can only find that one fir S905. Thank you.
          hi,
          there are two ways...
          preferred way...
          Download firmware
          use
          And create a bootable sdcard... then use reset button to boot Le from SD
          If everything works like you wish... you can use shh to give command installtointernal (this will write to nand)
          The second way..
          Download the flashable zip.. unpack to SD ( you get another zip, if I remember correctly)
          In android launcher use Update app... to install the zip file (this will format/overwrite android! )
          Alternative options...
          *Use Petrus Reboot app to boot into recovery...and install zip
          *You might be able to use Reboot...to boot into Le sdcard...also
          Please note... way1 was not available when I first installed Le , I used the Zip methode (unsafe method)
          Goodluck
            Thanks a lot Mitchell.
            I took LibreELEC-S802.S82.arm-8.0.0-2-alpha-devel.img.gz
            from http://download.drieschel.de/LibreElec/S82/
            to Rufus and pressed Start.
            SD shows:
            kernel
            kernel.img.md5
            system
            system.md5
            Boot starts and says:
            cp: can´t stat ´/flash/system´: No such file or directory
            ***Error in prepare_sysroot: mount_common: Could not mount /dev/System ***
            ### Starting debugging shell... type exit to quit ###
            sh: can´t access tty: job control turned off
            #_
            Do i have to search a device tree file first?
            Found this:
            "Download a device tree as instructed above and rename it to dtb.img. Copy the renamed file to main folder of SD card/USB drive - replace the one that's already there."
            Where can i get this for the S82?
            Or is it another mistake?
            Thank you!
            Edit:
            I tried several of demetris and drieschels images. "Filsystem corruption detected". "Read-only filesystem".
            My box is Mbox S83B V2.2 S802B/A P6330/ 2/16GB Mali 450.
            Which image do i have to choose for Kodi17?
            I use to format SD before writing image. Still stuck with errors.
            Used Libreelec USB-SD Creator
            Rufus 2.12
            2 GB Micro SD Kingston
            Thank you.
