Beelink SEA I Firmware Download And Update tutorial 101M0_20170225_ 16G & 32GB
Can you get the FIRMWARE ONLY update to work for the 32G SEA-I?
We were finally able to download "Only update the firmware tool" by opening its folder and downloading both files individually.
Also able to open install Launch "rtumdfsample" (keylin usb tool 0.0.8 - ver_1005811), and open "SEAI_102M0_32G_20170322" to add it .
But, we continue have a STALL at update problem:
When we click LOAD INFO button, a green progress bar appears for a minute, then nothing. No update progress at all in the weird multi gear icon "DEVICE" window once the green progress bar disappears.
ANY suggestions we would be TREMENDOUSLY grateful for!!! We feel like this should be brain-dead simple, but it's not... or maybe it is???
Help please, and thank you :0)
Originally posted by Dr. Angelo View PostCan you get the FIRMWARE ONLY update to work for the 32G SEA-I
PS. Noticed a couple of times my internet connection was not detected, although present & active. Therefore location could not be identified by main screen widget and android could not connect to google services. A reboot solves the problem.
superceleron .. can add navigation bottom bar. Need badly...MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Originally posted by KAA View Postsuperceleron .. can add navigation bottom bar. Need badly...
Originally posted by vadergr View Post1) Are you going to release a rom without hdcp restrictions in hdmi in recording?
2) The last rom has any version of kodi preinstalled?
2) No KODI/ fork included in firmware 102
Originally posted by Sunam View PostYes, it worked for me under windows 10. At the stage of powering the Beelink on, driver search was unsuccessful. Just needed to reboot the PC, launch rtumdfsample.exe and then to power Beelink off (unplug power cord) and on again. After this the first device slot in the software turned green, needed to click on green Android icon to start flashing.
There are currently 996 users online. 0 members and 996 guests.
