Status | Launched |
Launch Date | February 2017 |
Product model | AP34 |
Dimension | 119*119*20mm |
Processor Number | N3450 |
Cache | 2 MB L2 |
Instruction Set | 64-bit |
OS | Supports Windows 10 system and Linux system |
Language | Multi -language |
Intel CPU | Intel Processor N3450 2M Cache, up to 2.2 GHz |
Processor Graphics | Intel HD Graphics 500 |
Installed RAM | DDR3 4GB |
System Disk | Windows(C![]() |
Ethernet | 1000Mbps LAN |
WIFI | IEEE 802.11a/b/g/n/ac,2.4G+5.8G |
Bluetooth | BT 4.0 |
Antenna | External WiFi antenna |
Expand Memory | SD Card (Support 128GB) |
# of Cores | 4 |
# of Threads | 4 |
Processor Base Frequency | 1.10 GHz |
Burst Frequency | 2.20 GHz |
Scenario Design Power (SDP) | 4 W |
Cache | 2 MB L2 |
Button | 1*Power Button |
DC-in | 1*DC in Port |
USB3.0 | 3* Standard USB3.0 Port |
HDMI | 1*HDMI Type Port |
RJ45 | 1*RJ45 |
Headphone microphone | 1*Headphone microphone jack |
SD Card | 1* SD card slot |
Power LED | 1* power LED |
Reset | 1* Reset hole The operating system crashes, Please do not unplug the power. Press the reset jack, the system will automatically restart |
Power management | Adapter DC12V 1.5A(100-240V,50/60Hz) |
Work Environment | 5°C -- 35°C,30%--90% Humidity |
Storage Environment | -20°C -- 60°C,10%--90% Humidity |
Intel 64-bit | yes |
Intel Identity Protection Technology | yes |
PRECAUTIONS FOR USE | |
