My question is, what should I do now? Should I try connecting it to a PC at my friends house, should I use a diffrent firmware on the SD card, should I do something with the drivers? I exclude the hardware failiure cause it was working perfectly fine, it wasnt overheated, it didnt smell like a burned receiver, this looks fine, but i can't make it work. I lost any hope, you are the only possibility for me to rescue my box. If anyone knows what to do, how to do it preferably through an SD card (remember it is completely bricked, it doesnt show any screen, no signal), or has a complete pack of firmware files, please help, I would be really grateful.
Scishion V88 PRO problems with connecting the receiver to PC
Hello. Ive been trying to find an answer here, but unfortunately there is nothing that would work for me. I was watching a movie and the receiver just showed me a green screen and stopped responding to anything. I turned it off and tried to wait a little bit, but then just a red light showed up and nothing more. It doesnt respond to the remote control, I suppose it is bricked (after one day, great). I started looking up solutions in the internet, but I cannot connect my box to the PC. I have the drivers, I have the USB cable A to A, i tried using USB 2.0 as well as USB 3.0 (I have a laptop and Windows 10 x64). It just doesnt show up in the system, nothing, just like I didnt plug anything at all. Then I tried using the SD card as well, but nothing happened, nothing showed up. I can't find a complete firmware pack (I mean zip file, img file, uboot file etc), and I dont know if using such a pack helped.
My question is, what should I do now? Should I try connecting it to a PC at my friends house, should I use a diffrent firmware on the SD card, should I do something with the drivers? I exclude the hardware failiure cause it was working perfectly fine, it wasnt overheated, it didnt smell like a burned receiver, this looks fine, but i can't make it work. I lost any hope, you are the only possibility for me to rescue my box. If anyone knows what to do, how to do it preferably through an SD card (remember it is completely bricked, it doesnt show any screen, no signal), or has a complete pack of firmware files, please help, I would be really grateful.Tags: None
There are currently 2475 users online. 0 members and 2475 guests.
