TAP 1 Android 6.0 TV Box 905X
    2GHz Cortex-A53 CPU Bluetooth 4.0 Mini PC
    Model: TAP 1
    Type: TV Box
    System: Android 6.0
    Processor: S905X
    CPU: Cortex A53
    Core: 2.0GHz,Quad Core
    GPU: Mali-450
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: 32G
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,DTS,FLAC,MP3,OGG,RM,TrueHD,WMA
    Photo Format: BMP,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,RJ45,TF card,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: DLNA,Miracast
    External Subtitle Supported: Yes
    HDMI Function: CEC
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA batteries
    Product weight: 0.0050 kg
    Package weight: 0.0500 kg
    Product size (L x W x H): 7.00 x 7.00 x 2.00 cm / 2.76 x 2.76 x 0.79 inches
    Package size (L x W x H): 14.00 x 14.00 x 4.50 cm / 5.51 x 5.51 x 1.77 inches
    Package Contents: 1 x TAP 1 Android 6.0 TV Box, 1 x Power Adapter, 1 x English Manual
    Gearbest
    I have a strange problem with my FTMC setup.., after updating addons (and afrer TV Box restart) - cause android.process.media has stopped error..., and Appinstaller aplication stop working....
    There is a fix for this error - android.process.media has stopped
    1. In settings browse for - Application
    2. Before proceeding, look for options on the top right and toggle Show System. This may enable you to locate Media Storage from the list of applications if it isn’t already visible.
    3. Now search for the Media Storage application from all of the applications which are listed. Click on it.
    4. Clear data and disable...
    5. Now find Download manager and do the same for it...
    AppInstaller still will not working, but you can install everything through FileBrowser....
    I can get rid of this situation only with factory reset.., and forget about FTMC - and everything works without any problem...
    If somebody has some better solution - or better FW to flash on this Box - post it....
