This work would have not been possible without a lot of help and work from bluesmanuk followmsi
I have taken the recently released stock firmware Dolamee_D5_rtl8189es_RK3229_6.0.1_20170224.img and taken it apart to accomplish the following.
Removed all excess bloat.
Removed all home screen apk's
Installed XBMC Launcher
Installed FTMC-16.1-armeabi-v7a-Build-24-RK-Version (huge amounts of thanks to the FreakTab communit)
Modified Boot logo
Added DRM Lvl 3 support http://freaktab.com/forum/tv-player-...-android-6-0-1
Petrus's reboot installed. It just works.
And then modified it to include TWRP and SuperSU.
A few notes for use of TWRP
Per followmsi 's quote above strongly recommend backup/restore of data partition of your device with TWRP.
I do not fully understand the ramifications or reasons of this but be warned.
Please be warned, use of this is AT YOUR OWN RISK!
Flashing instructions are just the same as the stock rom. I use Linux_Upgrade_Tool_v1.21 but that is only my preference.
I have uploaded the image file here (updated link)
And again thank you all for all of your help, And good luck to everyone.
Changelog :
V1.8 - DolameeD56.0.1TWRPSuperSUDebloatedKodiHomeScreen1. 8.img.zip
- Modified build.prop and injected into system.img
- ro.build.display.id=Dolamee_D51x8-Modified 6.0.1
- ro.build.version.incremental=20180319v1.8
- ro.build.user=tacotime82
