CX-919 Finless 4.2.2 Rom and 4oD TV
    Hi All!
    I’m running Bobs 4.2.2 Finless ROM and trying to access Channel 4 On Demand catch up TV.
    Every time I select a program to watch and view I get the spinning circle of the stream waiting to load, but it never runs!
    It’s driving me nuts!!!!
    On a laptop I’ll usually get a digital rights error, which goes away by reselecting the same TV show to play.
    I disabled SuperSU last night as people report 4oD won’t work with rooted devices, but even that didn’t work!
    Any advice anyone?!
    Cheers!
    Same problem here
    Donate to Finless
      Originally posted by androidhov View Post
      Hi All!
      Any advice anyone?!
      Cheers!
      That's odd, I can get 4OD, on my Galaxy S3, running Android 4.1....which is rooted!!
      This is in Ireland, using Hola Unblocker!!!
      I can also download, for play later, and get catch up, no DRM stuff...
      So, there is no problem with rooted devices...just to let you know.
      If you are in the UK, there should be no problem....I can't offer a solution, but there should be no difference in Android devices runnimng anything above 4.0....IMO.....
      unless it's a ROM thing?? can't see it though!!
