I had this box gt1 ultimate about a month now my Antivirus flags ((FotaProvider)) as malware its built in the system can't Uninstall had to use titanium to Uninstall. Question is will I get my ota updates.
FotaProvider
FotaProvider
Maybe posted in wrong section if so Moderator please move or put in the right place
I had this box gt1 ultimate about a month now my Antivirus flags ((FotaProvider)) as malware its built in the system can't Uninstall had to use titanium to Uninstall. Question is will I get my ota updates.Tags: None
Hi cdnflag ,
i dont think so , but the best Way is flashing with Pc , for your Box is support here
http://freaktab.com/forum/tv-player-...v-players/s912
if you have TB you have Root and can use Apps like Flaki SystemAppManager
to convert to UserApp to uninstall , but not every AV flag is really bad maybe
Whitlist.For Future Questions ask there.
nice Day
gefattern
Very likely to be adups - https://blog.malwarebytes.com/cyberc...s-old-and-new/
This was also discussed on these forums. Nearly every firmware that shipped with generic devices contained a variant of this malware within the fota framework.
You will not receive ota updates once you disable/remove the apk.
There are currently 2387 users online. 0 members and 2387 guests.
