MXQ-4K i can't to enter to recovery menu ( toothpick method)
    I have a MXQ-4K and i try to do update from my pc to the box, i using the "toothpick method" and RKBatchTool-v1.8 but the process failed. Now i can't to enter to recovery menu and after reboot it show a green screen.
    Please, I need your help for recovery my box.
    thank's
    Hi fecktor ,
    flash your Box once more but like here subcribed :
    http://ugoos.net/blog/rockchip-firmw...flashing-guide
    do it the same way on your RK Device.
    good luck
    gefattern
      Thank's for your answer, but i can't to enter to recovery menu hold the reset button. Please help me with the othet way for this, how i do it?
      Thank's
        I don't have this box. But referring to the link in gefattern's post, make sure you are using Driver Assistant 4.1, older versions did not work with my 3229 box.
        Also insure that you are using your TV box's OTG USB port.
        Using the assistant and with box not plugged to PC, remove the driver. Restart PC and install the driver with Driver Assistant, restart PC.
        When plugging the box to PC, try to use the PC's main PC ports(mounted to motherboard, not extensions).
        Good luck.
          RISCy Dude, i'm using driver assistant 4.4 and i could to update one time, but the process failed. Now i can't to enter the recovery menu from the box. When i press the reset button on the box the menu is not visible.
          I can't see any option only i see the MXQ-4K logo.
          Thank's
            Hi fecktor ,
            the Box must OFF then press "Recovery" with toothpick , while hold it press the "Start" button , when the Box starts to boot leave the "toothpick"
            after 2/3 seconds , if a Recovery is installed it will boot to it.
            good luck
            gefattern
              Gefattern, i tried with this method and nothing. My box hasn't start button. I "power ON" the box with the power cable, but anyway not work.
              I don't know what to do?
              Thank's
                Hi fecktor ,
                Do you have the Stockrom for flashing ???
                gefattern
                  No, but i can to download this program
                    Do you have any link for this?
                    Thank's
                      Hi fecktor ,
                      where did you buy it ???
                      please give more Specs , otherwise it is not possible.
                      good luck
                      gefattern
                        Hi fecktor ,
                        once more , try this :
                        https://androidtvbox.eu/new-firmware...60526-release/
                        Hint : for flashing no need for recovery
                        good luck
                        gefattern
                          I have this box.
                            Hi fecktor ,
                            if you really want to restore your Box use the linked FW with the linked Flashing Guide ,
                            dont use Batchtool , try Androidtool 2.30 & 2.35 for it.Second Tab for single .img flashing.
                            Load Firmware to Tool , connect the Box like subcribed in FGuide , if connected good ,
                            (found one LoaderDevice) , press erase IDB , wait till ready , a Message pops up , press
                            OK and then press RUN and the Tool beginns to flash , wait till 100% , wait 4/5 Minutes ,
                            disconnect it from PC to TV and have Fun with LP5.1.
                            Hope it helps
                            Hint : Look some RK Device Flashing Guides on YT and ask here if still something is unclear.
                            good luck , have a nice Day
                            gefattern
