CozySwan S400 Stock Roms and Tools/Drivers
    Haven't seen some of these tools before but again I am new so.............
    Just had these sent to me and wanted to share with others:
    CozySwan S400 4.2 Stock Rom: http://pan.baidu.com/share/link?shar...&uk=3509931586
    CozySwan Misc Tools / Drivers (please rename root dir it extracts to / chinese characters through config file not found errors) : http://pan.baidu.com/share/link?shar...&uk=3509931586
    Successfully booting on my S400 however the bluetooth on my device is either failed or.......... not compatible with this rom.
    Can anyone confirm if their bluetooth works with this?
    Hope it helps someone get their S400 working.
      Can you please share the Rom with me ?
      The Link goes only to the Tools.
      Thank You !
      My Problem is i have test a CustomROM and with this CustomROM my Screen goes black every 2-5 sek.
      I have test so many but nothing work, all ROMS bring me to the flickering Screen Problem.
      I have a Backup from my StockRom but this i cant flash sucessfull, when my Stick boot with the Backup it stops on 4 Linux penguins at the Top left.
      So, please share the right Stock ROM for the S400 with me my Friend
      Have a nice day and sorry for my bad english, i hope you understand me ?
      ... TVDroid
      > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
        TVDroid here is a list of all the files uploaded by the Cozyswan team.
        http://pan.baidu.com/share/home?uk=3509931586#category/type=0
        The problem with the Cozyswan s400 is there are two versions, with differing WIFI chips, so you need to download the one that is compatible with your WIFI chip.
        I have the Cozyswan s400 with the green sticker, with the AP6210 wifi chip. I am currently using this Firmware with the most success.
        百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
          Thank You but with this ROM i got the same Problem with the flickering Screen, see my Stick here ... http://www.freaktab.com/showthread.p...l=1#post115713
          I think my is a newer one or a clone !?
          ... TVDroid
            I would suggest contacting Spencer from Cozyswan. Show her the pics and see if it is actually the cozyswan s400 or a clone. If it's the real Cozyswan she should be able to get you straightened out.
              I write a email, now i hope i get the right ROM.
              The Sticker looks Original but who knows that Today ...
              I realy hope that my Stick can work again.
              ... TVDroid
                somone can tell if this is a clone? >>> Click image for larger version
ID:	431835Click image for larger version
ID:	431836Click image for larger version
                after insall of custom rom wifi and bl not work anymore. i put stock rom back and still no wifi. is there an solution ?? thank you
                EDIT:
                solved with rom from here >>> http://www.freaktab.com/showthread.p...-dan-Vsync-Fix
                but that mean i cannot put other rom at all ?
