any help. Thanks in advance
Viper4android Atmos for MXIII G
Well I have a Matricom G-box Q2 so this may not work for you. But what I did was use a file explorer and navigate to /system/vendor/etc
Copy the audio_effects.conf in that location
Navigate to /system/etc and paste the file you copied there
Once copied change the permissions to match the other files in the /system/etc folder
Install Viper and it should work this time, apparently the audio_effects.conf file is expected to be in the /system/etc location and is not there by default for some reason....
Now as far as the Dolby Atmos, you just need to find a version compatible with your box and flash the package in recovery. If you need one, let me know and I may be able to help. I've actually got a few things that blow just the Atmos by itself away...
Anyways, hope some of this helps.
There are currently 2379 users online. 0 members and 2379 guests.
