TAP PRO Android 6.0 TV Box 2/16Gb AC WIFI, Gig Lan, BT4:
    Octa Core ARM Cortex-A53 CPU Mini PC
    Model: TAP PRO
    Type: TV Box
    System: Android 6.0
    Processor: Amlogic S912
    CPU: ARM Cortex-A53
    Core: 2.0GHz,Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: 64G
    TV Box Features: 5G WiFi
    Decoder Format: H.263,H.264,HD MPEG4
    Video format: AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,DTS,FLAC,MP3,OGG,RM,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,RJ45,SD Card Slot,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: DLNA,ISO Files,Miracast
    HDMI Function: CEC
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Product weight: 0.0050 kg
    Package weight: 0.0500 kg
    Product size (L x W x H): 7.00 x 7.00 x 2.00 cm / 2.76 x 2.76 x 0.79 inches
    Package size (L x W x H): 14.00 x 14.00 x 5.00 cm / 5.51 x 5.51 x 1.97 inches
    Package Contents: 1 x TAP PRO Android 6.0 TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x English Manual
    Gearbest
    firmware on this box is q201_9377 userdebug 6.0.1 MHC19J20170301 , it has setting to adjust colour space for rgb fix on old Sony/Phillips tv , seems to a Beelink has BeeUi
      is there an android tv firmware for this box? just got one
        Ugoos Am3 firmware is mentioned to work on this , i have not tried it .
          Nexus GT1 Android TV 7.1.1 firmware working like a charm on this , wifi and remote and rgb fix all working , thanks Mangendanz link to firmware http://freaktab.com/forum/tv-player-...android-tv-7-1
            Thank you . Is front display working too on this Mangandenz firmware?
              No front display not working
                Ugoos am3 7.1.2 firmware working except remote , widevine L3 drm , link to firmware http://ugoos.net/index.php?route=pro...ownload_id=176
                Sent from my Redmi Note 5 using Tapatalk
                  Level 3. I assume no yourube in 1080p ?
                    Yes YouTube 1080p
                      Playing 4k YouTube auto 2160p no problems
                        I got my tap pro today. How to trigger flashing of image ?? I burned a image with amlogic burn card maker, but switching on with combination of reset hole doesnt work. Also remote button 3 lines button doesnt work either.
                          amlogic usb burn tool
                            I flashed it with "reboot to libreelec" apk, shortcut to boot from microSD card. Works great with Maegadanz Nexus Rom. Only thing that doesnt work is vfd front display. I will try to find vfd.display.conf file to see if it can be used in this ROM.
                              Well done , I ran into random freezes with that hence the switch to ugoos am3 firmware , I then added leanback launcher folder with APK to system/priv app and changed permission also added app drawer using same method to system/app folder . Found this might interest you also http://4pda.ru/forum/index.php?showtopic=905729
