TWRP Flashing
TWRP Flashing
Hi all how would i go about flashing a Twrp recovery img. is there a special way to get into fastboot for mk809iv rk3229 soc. I can't seem to get it to boot int fastboot.My Works @XDA:
AVD Rom Xperia J The Way Stock Should Be
Pre Root Xperia J 4.12
Deodex Xperia L
Deodex Xperia Z kitkat
Stock Xperia Icon's For CM11
Tags: None
There are one or two methods.
If you have a working box and it is rooted then you could install the Petrus Rebbot app from the app store that will allow you to boot into bootloader mode and flash the TWRP recovery image of your choice using android Tools 2.33/2.35.
Remember to rename the TWRP recovery image to recovery.imgLast edited by bluesmanuk; 26 March 2017, 18:52.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostThere are one or two methods.
If you have a working box and it is rooted then you could install the Petrus Rebbot app from the app store that will allow you to boot into recovery and flash the TWRP recovery image of your choice using android Tools 2.33/2.35.
Remember to rename the TWRP recovery image to recovery.imgMy Works @XDA:
Deodex Xperia L
Originally posted by gavster26 View Post
Ok thanks for the reply I will try it. I have tried cwm rom manager to boot into stock recovery but no recovery came up just an automatic format screen that wiped cache and data then it rebooted to system
Sorry about that.
There are currently 3076 users online. 2 members and 3074 guests.
