Mk808 with Finless 2.1 stuck at bootanimation
    hi guys.
    Can you please kindly provide any advise on how to get back into android? .
    I opened android and checked that it is original
    Flashed the Finless 2.1 mod with default settings (720p kernels and boot, 1gb default)
    However it seems to be stuck at the boot animation.
    I can see the black android and 4 red dots at the bottom flashing around but waited half an hour and still stuck there
    I tried unplug all usb device and I am using a good power supply
    I have successfully booted before but I suspect a recently installed app has screwed it up.
    Please help
    Thanks in advance
    Re: Mk808 with Finless 2.1 stuck at bootanimation
    Did you erase nand before flashing?
    Sent from my Barnes & Noble Nook Tablet using Tapatalk 2
      Yes definitely. Any clues as to how I can uninstall that recently installed app without refreshing?
      Sent from my GT-N7105 using Tapatalk 2
        Only way would be via ADB while in cwm or if possible (haven't tried it) while in flash mode ( don't know if its possible but give it a try).
        Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
