MXQ clone tv box ...usbA OTG port ? serial header ?
    hey folks
    I have a generic MXQ clone I opened it up and there appears to be a serial header ? and port 4 is marked as an
    OTG port although it is type A female ... if i wanted to directly connect it to my computer and use ADB
    would I make a type A male to male cable ? and if so should i cross over the data pins or just leave it straight through?
    second question is the header i marked as a Serial header .. actually a serial UART ? and such I can talk/listen to the board through it ?
    Type A plug straight thru for OTG
    Serial Uart header normally rx and tx are crossed
