New Firmware Egreat A5 Release (2017-04-01 v1.1.2.0)
    Note: Egreat A5 EN firmware includes "Release" version and "Beta" version,
    "Release" version firmware will be updated per month, you can download it click here
    "Beta" version firmware will be updated per week, which is only for some enthusiasts who like to test some new problems and solved problems in advanced.
    Egreat A5 EN Firmware V1.1.2.0 Release (OTA update optional)
    I. info
    A5BD_EN_Firmware_20170401_v1.1.2.0.rar
    Updating Time: 1st, Apr 2017 Saturday, at 9:10:41 a.m
    MD5:ECED4F4C553D52CF827DA56B297D11B5
    DownloadLink:
    II. Recovery the firmware instructions
    1.If your current firmware is before v1.0.1.5, please force to recovery V1.1.0.7 firmware, user datas will be erased. Then you can update to V1.1.2.0 by OTA directly, datas won't be erased.
    2.If your current firmware is v1.0.1.5 or after v1.0.1.5, you can upgrade the firmware by OTA directly or USB upgrade. And you also can force to recovery V1.1.0.7 firmware, user datas will be erased. The you can update to V1.1.2.0 by OTA directly, datas won't be erased.
    3. The force to recovery new version firmware instruction, please click here.
    Changelogs:
    01.Player : Added auto playback function when power on
    02.Player : Added color primaries show in the information window.
    03.Player : Added DTS compatibility options, support more DTS track
    04.Player : Added subtitle and OSD 3D depth adjustment
    05.Player : Added support DivX 5 format playback
    06.Player : Added support MVC 3D MKV format playback
    07.Player : Added support SUP external subtitles
    08.Player : Improved the 'volume setting is prohibited in passthrough mode' tips display location
    09.Player : Optimized Blu-ray menu compatibility
    10.Player : Optimized playback fluency when no open frame rate switching
    11.Player : Optimized network playback buffering
    12.Player : Fixed the problem of autoplay function.
    13.Player : Fixed the problem play may appear slight problems Caton
    14.Player : Fixed the problem that the player did not turn off the 3D after playing the game
    15.Player : Fixed the problem that the text does not show in the Blu-ray menu.
    16.Player : Fixed the problem where the True-HD 7.1 track may be incorrectly identified as 5.1
    17.Player : Fixed the problem of some DTS-HD audio slowplay unsmooth
    18.Player : Fixed the problem of Some format video and audio out of sync
    19.Player : Modify app name to EgreatPlayer
    20.Poster-wall : New poster analysis engine
    21.Poster-wall : Turn on the file mode to play the film display the details of the function.
    22.Poster-wall : Add DVD icon
    23.Poster-wall : Added folder containing .nomedia files automatically filter function
    24.Poster-wall : Added stacked ISO episodes to play in Blu-ray menu mode
    25.Poster-wall : Added the format table in the movie details page.
    26.Poster-wall : Optimize the "Edit" function does not need to wait until the search can be completed.
    27.Poster-wall : Improved poster wall load speed and improve the recognition rate
    28.Poster-wall : Improved text selected state display
    29.Poster-wall : Fixed the problem of Chinese movie name in edit window.
    30.Poster-wall : Fixed the problem of stacking different video errors together.
    31.Poster-wall : Fixed the problems poster sorting problem
    32.VidonXBMC : Can now be set to boot.
    33.VidonXBMC : Fixed the problem of flip eyes 3D.
    34.Settings : Added Russian, Vietnamese, Thai, French, Dutch, Spanish, Italy and other languages
    35.Settings : Optimized 2160P will be changed to UHD in the resolution menu.
    36.Settings : Optimized resolution selection list from low to high order.
    37.Settings : Fixed the problem that Wi-Fi could not connect hidded not spots.
    38.Settings : Cancel Dolby Vision options
    39.System : Add no U flash disk press RST key to restore the system
    40.System : Added flashing power led when updating firmware
    41.System : Fixed interfering and block ARC function
    42.System : Greatly enhance the network access speed
    43.System : Support MAC OS and Linux system copy large files(more then 1GB) to the machine's shared folder
    44.System : Fixed some OSD language translation
    45.System : Fixed the problem of Bluetooth device audio caton
    46.System : Fixed the problem of can not get the system time
    47.System : Fixed the problem of missing toolbar shortcut after upgrade
    48.System : Fixed the problem that the output resolution may change after reboot
    49.System : When adding network share address does not allow non-standard IP address
    Source: Egreat
