WeTeK Play 2 Hybrid 4K TV Box Amlogic 905-h 2/8GB Dual WiFi Gig Lan BT4.
Lets have a look at system and Information using the usual lot
Not a speed demon but should be able to handle most with ease.
I find the Weos ok to use and fairly easy to navigate, nice to have a fiddle with something a little different
Temps are ok, down to 42c when idle up to 55~ when pushed...
Good looking unit and have to Love those vents, Excellent.
Lots of features on the remote to keep the avid finger twiddler happy,
Good to see Multi Power Pack for all regions.
First Switch on
Settings
Settings
System Info
Main UI very ATV looking
DRM L1
Ram Truth
Storage Truth
Vellamo
Geekbench CPU Benchmarks
Full Details > https://browser.geekbench.com/v4/cpu/2327404
Geekbench Compute Benchmarks
Full Detail > https://browser.geekbench.com/v4/compute/581360
CPU-Z
Antutu 3d
Very Good Help/How to use via Youtube
Kodi 16.1/ WePlayer
A1 SD Benchtest
I've bought mine a while ago.
The only thing i really don't like is the remote!
Wetek play 1 had air mouse and this one is only IR mouse!
This was a bad choice by wetek
Beside that, is one of the best android box for DVB.
(to me the best one that combines both Android and DVB)
I'm waiting for Android 6 to come out to have Netflix 4k!
And a look at the bits that make it all happen
Under side
Top Side
Inside Top Lid and WiFI Antenna
Bits, Ram, eMMC Samsung, PHYceivers › 10/100/1000M Gigabit Ethernet, Genesys Logic 4 port USB 2 solution.
More Bits, WiFi, 905H CPU, Tv Tuner Sony DVB-T2 (incl.T2-Lite), DVB-T and DVB-C demodulator
Heat Sink, Thermal Pad, looks like its eating away at the CPU above
The classic launcher is much better, it can be downloaded from aptoide, it also works on any other TV box now.
i recommend weOS 1.4, also the new weOS disable navbar and status bar, which is a pain if you are used to using an airmouse.
The EPG does NOT work correctly in the UK, only now and next.
You cannot sort and reorder channel lists in wetv.
That said, i like the box, and is best one I've had.
But the weOS 2.0 was a really bad UI update.
Originally posted by Dandroid534 View PostThe classic launcher is much better, it can be downloaded from aptoide, it also works on any other TV box now.
But, beside that, yes, WeTV needs a few tweaks, but you also have the ability to use Libreelec that has other few millions different configurations
But overall, for me it's one of the best Android Box on the market (beside Nvida, but this is another level)
The media devices is designed and manufactured under demanding quality standards.
For instance, we support Widevine Level 1, Playready, Verimatrix, secureOS, and also HDCP DRM technologies.
Plus, we are able to reproduce 4k@60fps with Dolby, DTS, AAC licenses in force.
WeTek developed its own operating system - WeOS - based on Android, with an innovative and highly customizable UI.
WeTek is a proud supporter of open-source initiatives and in that sense, our devices are prepared for Dual Boot with both LibreELEC and OpenELEC JeOS.
Aptoide - the largest independent Android app store - comes pre-installed with WeTek all media devices as a result of our strategic partnership, allowing our users to experience an amazing array of apps.
All of this is supported by regular OTA updates and premium class customer support.
Play 2:
This powerful Android hybrid TV box, comes packed with features for the next level home theatre experience in glorious 4K/UHD. An internal modular tuner allows for worldwide satellite, cable, and terrestrial broadcast playback and recording.
Highlights:
Optical out
Modular tuner (DVB-C/T/T2 - DVB-S2 and ATSC)
WeTV app with IPTV integration
E2 downloadable lists
Recording to external storage devices
Web Interface for controlling the device via net browse within the same network.
Opportunities to improve:
Even though our remote lacks the air mouse feature, our launcher is totally prepared for navigation with the directional keys. Plus, Aptoide allows you to install various AndroidTV apps.
Such as Netflix (for Netflix, on Aptoide you need to disable the filter to access to our own store) To be able to accomplish this, open the AptoideTV app, head down to settings, select "Settings", then "Hardware Specs" and disable "Filter Applications".
WeTeK is already working on a small fix with Aptoide to be able to have all the apps directly on the store.
Android 5.1.1, in which WeOS is based can only take 2 HDDs at a time, HDD requires an external power supply
If you need further assistance, you may find tutorials, alternative ROMs, community support and more at http://wetekforums.com
The IPTV in wetv is really bad, and you cant reorder or even delete channels. I recommend progTV app instead.
the compatibility with apps is great, as is the widevine drm etc. And the fact it is android not android tv means more apps work, and no need for side loading and weird launchers. Big plus over the nvidia shield.
Bit well Big OTA update today, running Android 6.01 looking ok...Installed easy
Netflix 4k, and other things yet to find all good.Last edited by trebor; 13 June 2017, 21:51.
WeTek just released a new update for - Play 2 - featuring the highly anticipated WeOS 3.1 based on Android 6.0 (Marshmallow).
This new massive operating system upgrade allows users to experience Netflix in 4K directly on the device.
Play 2 owners just need to download the Netflix for AndroidTV version from Aptoide marketplace.
Other improvements include overall system stability with kernel fixes, various updates, and fixes for WeTV, as well as new Kodi 17.3 version and Aptoide’s latest update.
Users can now upgrade their devices to the latest operating system via OTA update directly from the box.
There are currently 1666 users online. 0 members and 1666 guests.
