I have been searching and searching but cannot seem to find anyone with the same box, or even problem as I am facing.
I was going to upgrade the firmware for my leelbox q3, in order to update KODI to v17.
I found a firmware that I was going to use and copied it on a SD card. I followed the toothpick method, and as I put the power back on, the Leelbox screen came on for about 2 second, then went off, and the box turned off completely.
When I plug it in now, it won't even switch on. The optical output shows red, so the power is definitely on, but the blue light in front only flashes faintly, nothing else happened.
Any ideas ?
