So I tried flashing via toothpick method using the AMLogic Bootmaker. ROM flashed successfully, blue light on normally and everything working. However, when you remove the SD Card and reboot, the box will be completely dead again, no Blue light and no signal to TV. With SD Card and reset buton, box works again.
Any ideas as this has been driving me up the wall. Thanks!
